1. petefromguelph's Avatar
    Hey guys! New here… just signed up after lurking for what seemed like forever. Trying to figure out my wife's Samsung Note (1). It is having some major battery issues and I have been trying to search around the forum to rectify them. I have done a couple of things and we are keeping our fingers crossed. First off, after downloading CPUSpy, we are ONLY running in 1512 mhz. No deep sleep and no other bars filled. Also, when checking what is causing battery drain, the number one culprit is "Bluetooth" at 40% drain. I have checked and bluetooth is not switched on. We have never connected a bluetooth device in the life of the phone (1.5 yrs). I can find a bunch of topics about not being able to turn bluetooth on, but barely any about switching it off (when the setting already says off). I was going to try to root the phone so I can tweak the CPU speed and see if that would help. I am not 100% confident in doing so as it seems quite complicated and I really don't want to mess anything up. We are losing about 70% battery in an hour or so. Thats with little to no usage. I just can't seem to see what is draining it so bad. Is the next step a factory reset?
    Thank you guys in advance and thanks for all of the help so far (through my lurking). We appreciate any help you can give! Not sure I posted in the right section… my apologies in advance if its wrong!
    Samsung Galaxy Note SGH - i717 with Jellybean 4.1.2 (newly updated from 4.0.4)
    01-04-2014 12:22 PM
  2. Golfdriver97's Avatar
    Maybe trying to clear cache in recovery? There may be some cached data that is causing a conflict. As for how to on your device I am not sure how, but I can post a possible method in a moment.
    From a Sprint Moto X using AC Forums app
    B. Diddy likes this.
    01-04-2014 12:24 PM
  3. Golfdriver97's Avatar
    [Guide] Rebooting into Recovery Mode for the Galaxy S2, S3, and Tab2.
    01-04-2014 12:25 PM
  4. petefromguelph's Avatar
    ok perfect. will read through. Would the factory reset essentially do the same thing? I have deleted all cache in all of those downloaded apps etc "All in one Toolbox", Android Tuner Etc. Will check this out though. Thank you SO much for the response.
    Pete
    01-04-2014 12:42 PM
  5. Golfdriver97's Avatar
    Pete
    Theoretically, a reset does it, but I have seen instances where it doesn't get everything for whatever reason.
    01-04-2014 04:34 PM
  6. petefromguelph's Avatar
    Perfect guys. Did the cache clean up from recovery and it seems to have at least removed the whole bluetooth drain. Will keep an eye. Thanks again guys!!
    Pete
    01-05-2014 11:19 AM
  7. Golfdriver97's Avatar
    Pete
    Hope everything works out. By the way, is your screen name a reference to K-Pax?
    01-05-2014 11:34 AM
  8. petefromguelph's Avatar
    lol nope. although it was on TV the other day. maybe sub consciously it was! Anyways... battery life seems to be improving but it is a work in progress. Now looking for a 1-2A charger for the car and my wife will be happy! Keeping an eye on the drains etc and doing cache clean ups through recovery. Really trying to avoid a factory reset.. may be a good idea though.
    Thanks again guys for your help. Love the internet!
    Pete
    01-08-2014 02:12 PM
  9. Golfdriver97's Avatar
    Pete
    Well, if it is a 1st gen Note with the original battery, the battery may just be showing it's age. You could consider seeing if a replacement battery is available, and worth the cost, as opposed to if you are considering upgrading, then the battery is irrelevant.
    A factory reset may not be a bad idea anyway.
    01-08-2014 10:06 PM
  1. How to turn off the camera sound on the Nexus 5?
    By michko in forum Google Nexus 5
    Last Post: 09-07-2014, 04:52 AM
  2. flip font doesn't work on Android 4.3
    By Chris8414 in forum AT&T Galaxy S III
    Last Post: 05-06-2014, 06:44 AM
  3. battery drains in 6 hrs
    By Jake Hilton1 in forum T-Mobile Galaxy Note 2
    Last Post: 01-10-2014, 08:18 AM
  4. Which is best kernel to use on this rom? GS3?
    By kabuchi in forum Samsung Galaxy SIII I9300
    Last Post: 01-06-2014, 03:42 PM
