1. coldtone26's Avatar
    Urgent help is required. I tried updating the firmware with Kies after which it said successful, the phone would not boot and is stuck at the samsung splash logo.
    I tried to fix it, but being a noobie, I think I made it worse. Can someone assist? Any help would be greatly appreciated.
    Thanks in advance.
    01-12-2014 12:42 AM
  2. aspot72's Avatar
    Thanks in advance.
    take out the battery (is it charged?) and gently press the battery connection pin in the phone. leave it without battery for about 2 hours. then reinsert battery and power up. sometimes after update it may take up to 15 min when phone start up.
    01-12-2014 06:10 AM
  3. coldtone26's Avatar
    I fully charged the battery last night.
    What you saying is that it would take long to reboot while showing the Samsung splash screen?
    01-12-2014 09:10 AM
  4. aspot72's Avatar
    Sometimes it can take long time. Usually 3-5 mins,rarely 15 and VERY RARE occasion up to 30 min.
    Sent from my XT1032 using Tapatalk
    01-12-2014 09:13 AM
  5. coldtone26's Avatar
    I'll try it now and leave it for a bit and see what happens. If no luck, what's the next step?
    You must forgive me. This is my first time working with an Android.
    01-12-2014 09:32 AM
  6. aspot72's Avatar
    If nothing happens reflash the ROM again. This time use Emergency Recovery in KIES. Let me know how it goes...
    01-12-2014 09:34 AM
  7. coldtone26's Avatar
    Do you have the steps for reflashing the ROM?
    How would I know if it was rooted?
    Another note, I remember when I clicked update OTA, it told me this was not allowed. Can't remember the exact message though
    01-12-2014 09:37 AM
  8. aspot72's Avatar
    Why are you bothering with ROOT? Do you need it? Sent you PM, do that first and then will see...
    coldtone26 likes this.
    01-12-2014 10:03 AM
  9. coldtone26's Avatar
    I was just asking. will check PM now
    01-12-2014 10:09 AM
  10. tsinkala's Avatar
    Hi.
    Have you found a solution to this issue. I have the same problem. So far I have also tried using odin to flash ROMs to the phone but the problem still persists - the phone can't boot to home screen. Also, there seems to be no way of entering recovery mode for the international version for the S3 mini GT-I190.
    Please help.
    T.S.
    01-19-2014 03:56 AM
  11. coldtone26's Avatar
    Try downloading CWM recovery. Load it via Odin. Then do a factory reset and reload firmware.
    01-19-2014 12:47 PM
  12. tsinkala's Avatar
    Hi,
    It has worked after using odin and using the CORRECT cwn. (I had tried a different version before and also manual/odin firmware upgrades to 4.1.2 ).
    The good thing is that finally after using i8190_buttonenable_cwm6.0.2.7.tar from http://forum.xda-developers.com/atta...0&d=1361802048 I managed to use Volume Up + HOME + Power Button and I entered into recovery mode. I chose wiping data, but after the phone rebooted my apps I installed were still there and the firmware version was 4.1.2.
    Thank you,
    Trevor
    Thank you,
    Trevor
    01-20-2014 03:01 AM
  1. Droid ULTRA led not working
    By AlphaXTaco in forum Motorola Droid Ultra
    Last Post: 01-12-2014, 08:15 PM
  2. Galaxy S3 Stock Camera App - Pics or video can't be viewed
    By RobbyRob123 in forum General Help and How To
    Last Post: 01-12-2014, 07:34 PM
  3. update to kitkat ??
    By Rizwan Manzoor in forum Samsung Galaxy S II
    Last Post: 01-12-2014, 06:26 AM
  4. Dropbox Photos Not Appearing In Gallery.
    By joshwithachance in forum Verizon Samsung Galaxy Note 3
    Last Post: 01-11-2014, 10:44 PM
