1. Leah_ganney's Avatar
    Hi - I have purchased the Klastor Kids tablet on Android 4.1, which is expandable to 32GB - we have purchased a 32GB Micro Sim card, which when connected to the PC via the USB lead displays as a file on the computer, however I am unable to save anything into the folder, we have tried to format the card, swap it with another etc
    I have also tried to move folders on the file manager app on the table but again am unable to save.
    Please help
    01-18-2014 05:13 PM
  2. patruns's Avatar
    Is the tablet mounting the card?
    01-19-2014 08:41 AM
  3. Leah_ganney's Avatar
    Yes can see the card mounted in the storage menu on the tablet
    01-19-2014 04:56 PM
  4. patruns's Avatar
    Can you read and write to the card when directly connected to a PC? What brand and class is the card? What format are you using and how are you formatting it?
    01-20-2014 10:06 AM
  5. Leah_ganney's Avatar
    Hi yes you can read and write to the card if it's put direct into the PC.
    The card is a class 10...I cannot see a brand name. Using FAT32 format.
    01-20-2014 01:43 PM
  6. patruns's Avatar
    Do you have another Android device that you can try formatting the card with?
    01-21-2014 09:49 AM
  1. HTC One 4.3 Lag problems
    By Borse2008 in forum HTC One M7
    Last Post: 01-05-2015, 09:42 PM
  2. Galaxy Note 3 USB 3.0 problem
    By Mike Minino in forum Samsung Galaxy Note 3
    Last Post: 01-22-2014, 09:00 AM
  3. Moto X and JVC head unit bluetooth problems.
    By tech addicted in forum Moto X (2013)
    Last Post: 01-19-2014, 06:42 AM
  4. Bluetooth streaming problem...conflicting audio apps
    By GTS21 in forum Verizon Galaxy S III
    Last Post: 01-18-2014, 12:54 PM
  5. LG G2 video editing problem
    By sialia in forum LG G2
    Last Post: 01-18-2014, 12:37 PM
