1. Jeffery Lutge's Avatar
    Ok I found a simple way maybe to fix the charging on s3 note. The 2 prongs get bent down. So the charger slips over them I bent them back up with a knife and it's fine now. My symptoms where slow charging Couldn't move my phone with out it stop charging. And it would still die when it was charging. So on the bottom your phone there two prongs you need to look at them and see if they are bent down too far most likely is caused by you shoving the charger in upside down after about mine up my phone charges super fast with no more problems of me moving it and it disconnected from the charger over and over and over and over and over and over and over and over and over and over and over and over again
    DOOKJOY6869 likes this.
    01-22-2014 05:54 AM
  2. Jeffery Lutge's Avatar
    you're having problems with your phone charger or anything and you're scared to send the prongs backup I might make a video on my girlfriends phone in the morning on how I did it just leave a message if you need help hope this works I'm really happy I figured I was wrong my phone almost had to send it back to Samsung but I figured out the problem so excited
    electricpete likes this.
    01-22-2014 05:56 AM
  3. electricpete's Avatar
    I'd like to see that video.
    01-25-2014 02:42 PM
  4. Jeffery Lutge's Avatar
    Ok my Gf works a lot
    01-28-2014 01:48 AM
  1. Replies: 4
    Last Post: 01-23-2014, 12:43 PM
  2. Problem since installing KitKat test build
    By peejay1977 in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 01-23-2014, 07:48 AM
  3. Problems with my battery
    By dsl4life in forum Google Nexus 4
    Last Post: 01-22-2014, 04:53 PM
  4. Avi problem
    By Livorno99 in forum Samsung Galaxy S4 Mini
    Last Post: 01-22-2014, 07:19 AM
  5. I think I may have found a problem on my Nexus 7 2013 :(
    By Sassi666 in forum Google Nexus 7 Tablet (2013)
    Last Post: 01-22-2014, 12:03 AM
