1. jacall84's Avatar
    Hello,
    I have had my Note 2 since last spring, I noticed in September that when using my original charge cord (plugged to wall) it would only charge when held in certain angles and very slow, I couldn't use while charging as it would drain it. I tried using my boyfriends nexus charger and that seemed to work. It was still slow but at least I didn't have to be constantly moved to certain angles (still discharged if used while on charger though)
    If I plug my phone in at night (let's say at 14% battery life) by morning, over 8 hrs later, it's only at 60 % and then drains completely in 4-5 hours, while I'm at work and not even using it, if I'm using it it goes down 2% a minute.
    This is getting so frustrating, I have no clue what's wrong. I've done a factory reset and nothing changed. If I use a universal docking station my phone actually charges very quick, at a normal speed. I'm not sure if it's the battery, usb port, or charger! Id appreciate any advice.
    01-23-2014 08:33 AM
  2. Golfdriver97's Avatar
    Hello,
    Welcome to the forums.
    It may be the charger. That would be the cheapest solution. Otherwise, I think you have issues with the charging port in the phone.
    01-23-2014 09:04 AM
  1. One Max or Note 3
    By squirtlover in forum HTC One Max
    Last Post: 03-08-2014, 09:28 AM
  2. Caller ID on Note 3
    By Ahmed Hesham in forum Samsung Galaxy Note 3
    Last Post: 02-20-2014, 09:18 AM
  3. Help for syncing my Note 3
    By sonic1519 in forum T-Mobile Samsung Galaxy Note 3
    Last Post: 01-31-2014, 08:20 PM
  4. Tablet battery drain at night.
    By Michael Romano in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-23-2014, 05:07 AM
  5. AudioOut_2 Wakelock Drain (4.3)
    By zetodavido in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-23-2014, 03:10 AM
