Results 1 to 3 of 3
    Default Missing Battery setting - Lenovo a820
    Hello,
    I have a Lenovo a820 with Android 4.1.2.
    It looks like the battery setting is missing and I cannot check the battery status/use.
    As far as I know it should be in the Device section, but it's not there (see screenshot).
    Also, when the battery is getting low, I get a pop-up message telling me to cahrge the phone, and there is an option to check the battery use, but when I click it nothing happens (see screenshot).
    Does anyone experienced similar issues and know a solution?
    Cheers,
    Marcin
ID:	103077 Click image for larger version.
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,733 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Missing Battery setting - Lenovo a820
    Quote Originally Posted by Marcin Grzelak View Post
    Hello,
    Cheers,
    Marcin
    Welcome to the forums.
    You are correct. There should be a battery function in Settings. I would suggest GSAM battery app. Many people like it, and at least it is a method to monitor battery use.
    https://play.google.com/store/apps/d...m.gsamlabs.bbm
    Thank you for the suggestion.
    Golfdriver97 likes this.
  1. Battery drain is really really bad on my Galaxy S4
    By Aussrh420 in forum Samsung Galaxy S4
    Last Post: 02-04-2014, 05:02 PM
  2. S3 severe battery drain
    By HelpNeededSlll in forum Samsung Galaxy S3 I9300
    Last Post: 02-02-2014, 12:25 PM
  3. Galaxy S4 keeps shutting off and I doubt it's the battery.
    By Soniku in forum Samsung Galaxy S4
    Last Post: 02-02-2014, 03:32 AM
