1. Rossotron's Avatar
    Hey guys, i'm hoping you can help me.
    I've got a tablet with Android 4.1.1. A few weeks ago it started telling me that my removable microsd card (Sandisk 32GB) was damaged so I sent the card back to the store and got a replacement.
    The replacement arrived yesterday and I popped it in the tablet only to be met with the same problem. I tried the card on my girlfriends tablet and it worked fine. She took the microsd card from her phone and tried it in her tablet and that also worked fine, but when I tried it on mine, it had the same problem. So it would appear that its the slot thats faulty. Could this possibly be a software issue? If so, would doing a factory reset on my tablet sort it out? If its a hardware issue, how would I go about fixing it? Is it a costly job?
    Many thanks in advance for any help- please let me know if you need any more information.
    02-07-2014 03:16 AM
  2. Golfdriver97's Avatar
    Welcome to the forums.
    My first guess is that it is a hardware issue. But a Reset wouldn't hurt. Back up all your stuff to your PC then give it a go.
    02-07-2014 09:19 AM
  1. LG G2: problem when flashing customROM 4.4 AOSP
    By Brandon Shea in forum LG G2
    Last Post: 06-01-2014, 08:12 AM
  2. Problems with speaker
    By Taadis Markevicius in forum Samsung Galaxy S4
    Last Post: 02-07-2014, 07:16 PM
  3. audio problems with video camera
    By animaledizona in forum Samsung Galaxy S3 Mini
    Last Post: 02-07-2014, 02:29 PM
  4. Play Store Big Problem
    By raptomic in forum Google Play Store
    Last Post: 02-07-2014, 09:22 AM
  5. What is an invalid SIM card ?
    By stalemate1 in forum General Help and How To
    Last Post: 02-07-2014, 05:57 AM
