1. inc55's Avatar
    Hey guys this is my first post. I've recently switched from a long iphone history to the note 3 and regret all those iphone years. Well one feature I do miss and was wondering if android has it. When I type on the iPhone and press the Sym key to select a question mark or other symbol the keyboard would change back to the alphabet and on android I have to press symbol again which is a bit annoying. Any fix around this?
    02-22-2014 02:19 PM
  2. Golfdriver97's Avatar
    Welcome to the forums.
    It has been a while since I used Samsung's keyboard, but maybe hitting space bar might shift it back. If not, there may be an option in Settings>Language and Input. However, you can always try a different keyboard as well.
    Since you are new, have you posted in the Intro forums and said hello to the rest of the community?
    02-22-2014 11:05 PM
  3. inc55's Avatar
    I will do that now. Thanks for the reply.
    02-27-2014 02:15 AM
  1. TMO Note 3 not compatible with Google wallet
    By raju130000 in forum T-Mobile Samsung Galaxy Note 3
    Last Post: 02-26-2014, 04:46 PM
  2. Verizon Note 3 On Tmobile SLIGHT Issue Need Help Please
    By airgreek in forum Verizon Samsung Galaxy Note 3
    Last Post: 02-23-2014, 12:52 PM
  3. Please help... Play Store HOME PAGE will not load
    By Arielle Williams in forum Samsung Galaxy S4 Mini
    Last Post: 02-22-2014, 02:47 PM
  4. Android Tablet with 4.2.2 SD card problem. Please help!
    By md363 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 02-22-2014, 01:14 PM
  5. Galaxy note II problem with connecting to wifi after upgrading to jelly bean
    By ANDREW AGANGA in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 02-22-2014, 06:58 AM
