Results 1 to 5 of 5
    Default Insane battery drain while device locked
    Hi all,
    I have a rooted Note 3 andr realize that my battery has been draining like crazy even when I'm not using it. Something like 7-10% per hour.
    The issue seems to improve if I turn mobile data off. And doesn't happen at home when connected to Wi-Fi.
    I've checked with BetterBatteryStats, and found nothing that would actually cause such a huge drain in battery.
    My battery could drain over 50% with only 5 minutes of screen time
    My workplace also has a relatively weak cell signal. Could this be the cause?
    When I try to place the SIM card in my iPhone 4S, the battery only drains 1% per hour. So this issue seems specific to my Note 3.
    Any help would be appreciated!
    Sent from my SM-N9005 using AC Forums mobile app
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,730 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Insane battery drain while device locked
    Have you tried a reboot?
    Like a restart? Yes
  4. #4
    Posts
    Global Posts
    32,730 Global Posts
    Carrier
    There might be a problem with the sim reader
    From a Sprint Moto X using AC Forums app
    Nope, SIM reader works fine
  1. Battery issues, possibly since update?
    By ao7415 in forum Android 4.4 KitKat
    Last Post: 11-04-2014, 03:20 AM
  2. Note 3: hand wave for quick notifications while in sleep
    By mayconvert in forum AT&T Samsung Galaxy Note 3
    Last Post: 03-13-2014, 10:14 PM
  3. Can an app widget be installed on the lock screen?
    By newbie40 in forum Verizon Samsung Galaxy S4
    Last Post: 03-12-2014, 08:31 PM
  4. Google Android Device Manager
    By jaipreetrana in forum Android 4.4 KitKat
    Last Post: 03-12-2014, 03:38 PM
  5. Replies: 0
    Last Post: 03-12-2014, 02:11 AM
