Results 1 to 1 of 1
    7coled's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Android system draining battery
    After flashing Vanir 4.3.1 stable and 4.4.2 nightly on Verizon Galaxy S3, my battery would last from 5 to 6 hours on average vs. 10 to 14 on any other rom. The cause of this was the Android system using over 70% battery and screen like 15%, on other roms it's the screen that uses 70% and Android system using like 2 or 3%. I installed watchdog task manager and it detected that qrngd, a Linux process that is packaged in the android system, was the culprit by using around 83.4% of usage. I did some research and couldn't find much about it. Does anybody know what it really does or if I can safely stop it somehow? It's really annoying and idk if it's the kernel and I should flash a new one. I never have any luck flashing kernels so I don't really want to unless I have too. Any response would help.
  1. Replies: 1
    Last Post: 04-08-2015, 08:31 PM
  2. Android Wear & Samsung
    By chefmorry in forum Android Wear
    Last Post: 06-25-2014, 08:17 PM
  3. Nexus 5 battery comparing with iphone 5.
    By lambrosio in forum Google Nexus 5
    Last Post: 04-28-2014, 11:01 AM
  4. New Here, not to Android
    By Gonzalo Martino in forum Introductions
    Last Post: 03-21-2014, 05:03 AM
  5. What's your opinion on Android Wear?
    By wizzrah in forum Android Wear
    Last Post: 03-20-2014, 08:34 AM
