Results 1 to 5 of 5
Like Tree2Likes
  • 1 Post By neonworm
  • 1 Post By B. Diddy
    Karim Yousry's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Is using so much ram can drain the battery ??
    My battery started to drain fast and i dont know why .. i thought because my ram is always used highly .. my ram is 1gb and the average using of it while i'm not opening any apps is about 68% to 73% .. is that even normal !! .. and can this cause my battery to drain !!?
  2. #2
    Sharishth's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Is using so much ram can drain the battery ??
    using anything in an smartphone too much can drain the battery specially when it come to hardware. yeah it could be one of the reasons but there are other reasons too. you can always use great apps like clean master (available at play store). Or your phone is old now.another possibilities are that your screen brightness is too high or your wireless connections like Bluetooth or Wi-fi is kept on for a long time or you don't have good battery backup.Sometimes features of phone also takes up much of a battery like nexus 5.
    also try searching for battery saving tips.
  3. #3
    Game Zone's Avatar
    Posts
    Global Posts
    14 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    There are background apps who are running , drain baterry and RAM freeze them with Titanium Backup or try a task killer
  4. #4
    neonworm's Avatar
    Posts
    Global Posts
    3,232 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Game Zone View Post
    Don't use a task killer. It is normal and actually good for the phone if the RAM is full. That is how Android works. Task killers can actually make the phone slower and/or use more battery.
    B. Diddy likes this.
  5. #5
    B. Diddy's Avatar
    Posts
    Global Posts
    78,127 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    neonworm likes this.
  1. Replies: 1
    Last Post: 07-04-2014, 12:49 AM
  2. Wow T-mobile service is bad....
    By Closingracer in forum T-Mobile
    Last Post: 04-03-2014, 10:21 AM
  3. Can I transfer a Note 3 from Verizon to T-Mobile.
    By rndm21 in forum Samsung Galaxy Note 3
    Last Post: 03-24-2014, 01:41 PM
  4. battery doctor app
    By Paskell in forum Google Nexus 5
    Last Post: 03-20-2014, 11:12 PM
  5. How long does the oleophobic coating on the screen last?
    By legaldeejay in forum Verizon HTC One
    Last Post: 03-20-2014, 05:18 PM
