Results 1 to 6 of 6
    Default Internal storage problem
    Hi Members & Mods !
    On my previous thread posted i didnt recognise what happens to my tablet which runs on 4.1 jelly bean.It cant shutdown i have to reset it & didnt install any app but only able to save files.
    What now i find is that its internal storage converted to sd card storage & its showing internal storage showing 0 kb & sd card storage showing 4.8 Gb whether i didnt insert any sd card.
    How can i fix that problem?
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,696 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Internal storage problem
    I looked over the other thread, and if you had any mainstream tablet, I would say reflash the stock ROM. Since it can't be found, I don't know what else to suggest.
    Bilal Saleem1 likes this.
    How to reflash ROM ?
  4. #4
    Posts
    Global Posts
    32,696 Global Posts
    Carrier
    Quote Originally Posted by Bilal Saleem1 View Post
    First thing is to find the proper file. If you can't I don't know what to suggest.
    Sent from my HTC One_M8 using AC Forums mobile app
    Which file ?
    does i have to connect my tab to my pc can solve problem
  6. #6
    Which device u have?? Go to google find stock rom for your device... And flash tool... Then check the procedure how to flash yr device... Then flash it... May b the problem will solve...
    The world is going to hell... I m driving the Bus
  1. Calendar/S Planner problem
    By Scucas in forum Android 4.4 KitKat
    Last Post: 11-10-2016, 12:07 PM
  2. Can't use S4 as a storage disk when connecting through USB.
    By dickharper in forum Samsung Galaxy S4
    Last Post: 07-24-2016, 05:19 PM
  3. Replies: 4
    Last Post: 05-01-2014, 12:58 PM
  4. Problems with kitkat on galaxy s2
    By Skaistike in forum Android 4.4 KitKat
    Last Post: 05-01-2014, 09:18 AM
  5. Help! Wifi problems
    By Calvin Hoang in forum Google Nexus 7 Tablet (2012)
    Last Post: 05-01-2014, 04:54 AM
