1. classic20's Avatar
    I have a rooted HTC One X with stock Sense 5 Android 4.2.2 and stock kernel. The phone is underclocked to 1Ghz and my current governor "Ondemand" is tweaked a little in my hopeless tries to expand the battery life of my miserable phone.
    As you can see from the screenshots, Kernel (Android OS) uses A LOT MORE power that it's supposed to. It's always in second place (right behind the app I most use during the day, like Facebook or Whatsapp).
    What can be the cause of this? Faulty kernel or a faulty battery? If you think I should change kernels, what kernels would you suggest that have good battery life and work with the stock ROM of the HTC One X?
    Attached Thumbnails 4.2.2 OS using too much battery?-screenshot_2014-07-07-16-33-01.png   4.2.2 OS using too much battery?-screenshot_2014-07-07-16-33-18.png   4.2.2 OS using too much battery?-screenshot_2014-07-07-16-33-48.png
    07-07-2014 07:21 PM
  1. Battery life really THAT bad?
    By FaintDeftone in forum Samsung Gear Live
    Last Post: 10-17-2014, 05:22 PM
  2. s4 battery drain
    By burnowt00 in forum Ask a Question
    Last Post: 08-15-2014, 11:40 AM
  3. Weird battery problem
    By androidgirl3107 in forum Samsung Galaxy SIII I9300
    Last Post: 07-07-2014, 10:11 PM
  4. Locked out of android phone (too many pattern attempts)
    By Unregistered in forum Ask a Question
    Last Post: 07-07-2014, 04:27 PM
  5. How to update my OS?
    Last Post: 07-07-2014, 03:57 PM
