Results 1 to 2 of 2
    Exclamation Drained battery after jelly bean update help!!!!!!
    So i've searched high and low looking for a solution to my problem and i have seen that there has been a few people having this problem so here it goes
    Updated phone (Motorola RAZR i) to the new Jelly bean 4.2.
    Battery levels is drained like after a few minutes on
    Ive done a factory reset and reloaded all my apps and checked other programes running in the backgrond and everything is fine.
    WHAT THE HELL IS GOING ON?!
  2. #2
    Default Re: Drained battery after jelly bean update help!!!!!!
    UPDATE: Disregard the picture attached. Somehow check in got checked as I was doing a screen capture. So did location history.
    Go to maps, press the menu button, and go to settings. Choose Location. Turn off reporting. I have everything turned off. This should stop the background reporting on maps. If you use Picasa apparently there is an issue with the gallery trying to sync Picasa constantly in the background. Check Facebook and determine if you really need notifications on. I turn everything off with Facebook. I already get email notifications about updates, so I don't need the app to do it. I also manually sync contacts in Facebook with existing contacts. Check for Motorola apps that may have an update that does not update thru the Play Store. You will have to open them and see if there is an update. My wife's GS3 had a Samsung update to Allshare Cast that was trying to update in the background and eating battery.
    Hope this helps. I'm using a Note 2 so my battery life is great. But my wife has a GS3 and I had to do these after her 4.1.2 update.
    Sent from my SAMSUNG-SGH-I317 using Android Central Forums
    Attached Thumbnails Attached Thumbnails Drained battery after jelly bean update help!!!!!!-uploadfromtaptalk1363834402839.jpg
  1. Awful battery life after Jelly Bean update.
    By Staser9er in forum AT&T Galaxy S3
    Last Post: 05-14-2013, 08:41 AM
  2. HELP! Not able to open camera album after Jelly Bean update!
    By liana ramlee in forum Android 4.1 / 4.2 Jelly Bean
    Last Post: 05-14-2013, 12:27 AM
  3. No Service, Unknown Baseband after Jelly Bean update
    By mtkohl85 in forum Sprint Nexus S 4G Rooting, ROMs, and Hacks
    Last Post: 03-22-2013, 11:07 AM
  4. Poor Battery Life After Jelly Bean Update
    By FSchmitthammer in forum Samsung Galaxy Note 10.1
    Last Post: 02-06-2013, 05:04 PM
  5. Weird too many SMS notification after jelly bean update
    By sisblub in forum Verizon Galaxy Nexus
    Last Post: 02-02-2013, 09:03 PM
