Results 1 to 7 of 7
    theonecalledben's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Android 4.4's launcher not installed correctly on Nexus 4
    Installed the OTA 4.4 update for Nexus 4 earlier, which went fine except it didn't include the home launcher. So I just installed that separately except it doesn't appear to have worked correctly. The bars are not transparent when the phone is locked, and I'm sure that's not the only thing that shouldn't be different. Any help on how to get the launcher completely working? (I'd take screenshots but that function isn't working...)
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,762 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
    Default Re: Android 4.4's launcher not installed correctly on Nexus 4
    The factory 4.4 update on the Nexus 4 doesn't include that feature. If you found the Nexus 5 launcher and sideloaded/installed that, and still don't have those features, then it could be an issue with the .apk you found.
  3. #3
    ajpri's Avatar
    Posts
    Global Posts
    70 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The lock screen is separate from the home screen.
    Posted via Android Central App on my Samsung Galaxy Tab 2 7.0 (Android 4.2.2)
  4. #4
    itic's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Same here. Loaded both from xda: [APPS][4.1+] Google Experience Launcher (GEL App + Google Search App) - xda-developers.
    The icons are larger and i can swipe left for google now but none of the other features are present. Can i uninstall them and try again
  5. #5
    MetalMike901's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Make sure your Google Search app is the most current before installing GEL. Should be 3.1.8.914827
    Posted via Android Central App on my white Nexus 4 with StraightTalk
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by srkmagnus View Post
    I might have installed a fan's attempt at replicating the N5 launcher on N4 rather than the real deal.
    Quote Originally Posted by ajpri View Post
    I've seen videos of the Nexus 4 with Android 4.4 where the lock screen bars have also been transparent.
    Quote Originally Posted by MetalMike901 View Post
    I definitely have that version (the latest).
  7. #7
    someguy01234's Avatar
    Posts
    Global Posts
    1,820 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    There is no issue, you are asking for something that Google has never made for the Nexus 4. The Google launcher is for the N5 only, and it only affect the home screen, the lockscreen is separate. The videos you see on youtube with the transparent lockscreen are running root with modification or custom roms.
    You can flash the modified framework to make lockscreen transparent if you want.
  1. Music from torrent app to music player on phone?
    By Dustin Short in forum Verizon Samsung Galaxy Note 3
    Last Post: 08-15-2016, 05:33 PM
  2. why is android wasting all my battery
    By lzelanka in forum Moto X (2013)
    Last Post: 12-13-2013, 01:47 AM
  3. Nexus 5 or Note 2?
    By Yogi217 in forum General News & Discussion
    Last Post: 11-27-2013, 01:52 PM
  4. Stuff non-Nexus users will not get with 4.4
    By JeffDenver in forum Google Nexus 5
    Last Post: 11-22-2013, 08:16 PM
  5. SGH-1747m on AT&T 4.3 update?
    By dlrogers81 in forum AT&T Galaxy S3
    Last Post: 11-22-2013, 05:09 PM
