Results 1 to 12 of 12
    Default Bluetooth and lock screen. Please help!
    Hi. Not sure if this is the right place but I have a nexus 4 that I have just updated to Kitkat. I also just bought a Bluetooth portable speaker (jbl flip) which I am happy with (only paid 2 through tesco clubcard boost scheme!)
    HOwever when it is streaming to the speaker and the screen locks if I open the screen by entering my pass code the music really stutters.
    I wondered if there was a way of setting locks screen to Not come on when Bluetooth streaming? I have contacted jbl who advised shutting down all apps except play music but it's made no difference.
    Anyone any ideas if this is a common issue with bt speakers or is it just the ones I have bought?
    Hope someone can help and apologies if in the wrong forum (wasn't sure if it should be under nexus 4 or Kitkat!)
  2. Thread Author  Thread Author    #2
    Default Re: Bluetooth and lock screen. Please help!
    Might this be a KitKat issue? My wife's nexus 4 which isn't updated yet doesn't have any sound issues when locking or unlocking.
    I turned off ny password but still sane problems
  3. #3
    I don't know if this makes a difference, but does matter which music player app you use?
    I'll need to give that a try. I rather like the google music app though.
  5. #5
    I have not noticed any stuttering through the Google Music app on either my N5 or N7 (2013) when streaming audio to a bluetooth headset.
    Its only when I press the home button to lock the screen or when swiping to unlock
  7. #7
    Here's a thought... maybe the stuttering isn't due to the act of locking/unlocking, but rather the sound that plays. Are screen lock sounds turned on (Settings > Sound > Screen lock sound)? If so, turn them off. If they're already off, then this may be an issue with Bluetooth.
    Thanked by:
  8. Thread Author  Thread Author    #8
    Good thought. I do have lock screen sounds in. I will disable them and try again
    Will report back later!
    By Jove! I think you've cracked it!!
    Will test fully later this week but a quick check this morning with lock sounds off shows no issues.
    Thanks!
    Thanked by:
  10. #10
    Hi having the same issue.
    Nexus 4 KitKat stock and Jabra Soulmate speaker.
  11. Thread Author  Thread Author    #11
    Having tested again I can confirm that it was the lock screen sounds that were causing the issue. I turned those off and no more problems!!!
    Thanks Patrick!!
    Thanked by:
  12. #12
    With the recent 4.4.2 update this was solved. I have the lock screen sound again without problems.
  1. Nexus 7 Desperate for some help or feedback!!
    By Daftyman in forum Google Nexus 7 Tablet (2012)
    Last Post: 01-18-2014, 10:33 PM
  2. Getting Frustrated So Help Would Be Nice
    By Hunsdale in forum General Help and How To
    Last Post: 12-03-2013, 12:08 AM
  3. Samsung Galaxy SII - Dear god help!
    By bex3110 in forum Samsung Galaxy S II
    Last Post: 12-02-2013, 11:21 PM
  4. Dear god help!
    Last Post: 12-02-2013, 02:25 PM
  5. Replies: 7
    Last Post: 12-02-2013, 12:54 PM
B
