1. myusernam's Avatar
    As the title suggests just upraded nexus 5 and the flash control is greyed out even with HDR+ deselected. I tested the flash by sheilding light with my hand and it works (on auto) just greyed out cant change from auto to manual. Pretty ordinary if you ask me. would like to force flash on on occasion.Click image for larger version.
    Attached Thumbnails 4.4.2 nexus 5 camera flash greyed out even with HDR+ off-noflash.jpg
    12-12-2013 10:32 PM
  2. EviI's Avatar
    Did you try restarting your phone?
    Try turning off Scene Mode and Incandescent white balance.
    12-13-2013 12:12 AM
  3. yfan's Avatar
    It appears that the SCE (or the bulb) mode already has auto flash as mandatory. Turn those off and you'll have your flash option back.
    12-13-2013 12:41 AM
  4. myusernam's Avatar
    Thanks!
    12-13-2013 03:35 PM
  1. Need help with Glance
    By rjack22 in forum Pebble Smartwatches
    Last Post: 02-10-2014, 11:02 AM
  2. Now over a year old, should I buy a Nexus 10?
    By matty3054 in forum Google Nexus 10 Tablet
    Last Post: 12-29-2013, 12:40 PM
  3. I need help with profile settings
    By ZClock in forum Google Nexus 7 Tablet (2012)
    Last Post: 12-13-2013, 09:08 PM
  4. Connecting to Wifi with a login page.
    By Madzmadz13 in forum Google Nexus 7 (2012) Rooting, ROMs, & Hacks
    Last Post: 12-13-2013, 08:35 PM
  5. Nexus5 Camera
    By kyoo in forum Google Nexus 5
    Last Post: 12-12-2013, 08:22 PM
