03-15-2015 07:18 PM
26 12
tools
  1. Troothdotcom's Avatar
    new to these forums so please give me a break (not a kit kat joke or is it) if this is in the wrong place. i would love some help or insight as to which may be the biggest problem. i updated to 4.4.2 to same day i updated my Instagram app (NEXUS 4) and my battery has been dying at an accelerated rate. my battery app shows that IG is using up to 37% of my battery at a time higher than my screen at 12%. if it is the IG update and not the 4.4.2 update does anyone know where i can get an older version of IG? thanks!
    12-22-2013 07:05 PM
  2. draconianchaos's Avatar
    You can uninstall the updates to Instagram. Can you screenshot the battery screen so people can better assist you.
    What version did you update from? How was battery then?
    12-22-2013 07:12 PM
  3. Troothdotcom's Avatar
    here is screen shot of my battery drainage.
    previously i was using Android 4.3 and skipped all the way to 4.4.2
    12-22-2013 07:21 PM
  4. draconianchaos's Avatar
    OK now click the drain graph so we can see a better idea of what's happening with the phone.
    12-22-2013 07:36 PM
  5. Troothdotcom's Avatar
    i have not clue what this all means.. =/
    12-22-2013 07:41 PM
  6. draconianchaos's Avatar
    Well for starters you've been charging your phone alot. Do you know where to uninstall the updates to Instagram?
    12-22-2013 07:58 PM
  7. Troothdotcom's Avatar
    yes i have my phone dies way too quickly. i have no idea. idk what to do IG is a big part of my spoken word life so i need it id hate to have to remove it completely.
    12-22-2013 08:05 PM
  8. draconianchaos's Avatar
    An app I've seen bandied about is wakelock detector. This might be of some help.
    12-22-2013 08:10 PM
  9. Troothdotcom's Avatar
    seems i need to root for that app also just like gsam =/
    by any chance do you know where i can get the apk for an older version of IG?
    12-22-2013 08:14 PM
  10. draconianchaos's Avatar
    Uninstalling the updates didn't help?
    I found this and just installed to my device. https://play.google.com/store/apps/d...kelockdetector
    Also you could search through xda and try to get some variety of app ops for 4.4.2 that will require root according to http://www.xda-developers.com/androi...n-permissions/
    12-22-2013 08:20 PM
  11. Troothdotcom's Avatar
    not sure how to uninstall the update i just completely uninstalled the app. and that app you suggested needs root and im not rooted. would love to be but afraid of doing it wrong
    Also you could search through xda and try to get some variety of app ops for 4.4.2 that will require root according to Xposed Module Brings Back App Ops on Android 4.4.2 to Give Your Control of Your Application Permissions – xda-developers
    12-22-2013 08:39 PM
  12. draconianchaos's Avatar
    OK my bad I was confused by factory apps.
    12-22-2013 09:20 PM
  13. faustoromano's Avatar
    Hey, I've got a Nexus 5 and the problem is the same. What I have found that helps a lot is to delete the app from the background running applications (lower right corner button and then slide all the garbage out of there). If instagram is not running in the background I get normal battery drainage (a day use). If I don't do that, my phone lasts 6 hours maybe.. I suppose it is an instagram compatibility issue.. This is just a workaround, it would be nice if those guys fixed it.
    12-24-2013 12:58 PM
  14. yfan's Avatar
    Are you on delvik or art? Try reinstalling instagram and see if it fixes anything. If you're on ART, try switching back to delvik.
    Sent from my Nexus 5 using Tapatalk
    12-25-2013 11:57 AM
  15. b3dlam's Avatar
    How do I uninstall the updates to instagram? It is also killing my battery
    that.rick22 likes this.
    12-30-2013 10:27 PM
  16. draconianchaos's Avatar
    I was confusing aftermarket apps with factory apps. As far as I know the updates to an aftermarket app can't be uninstalled. The best course of action would be hunting down an old version of the apk.
    01-03-2014 04:33 AM
  17. schox's Avatar
    Samme problem "here" - Nexus5 - Android 4.4.2 (factory reset after OTA)
    App reinstalled several times - cashe cleared.
    Will try ART to see if there is any difference...
    01-04-2014 04:40 PM
  18. xceeder's Avatar
    Try searching on Google for the previous version of instagram also try things like clicking on restrict background data in settings and check if auto refresh/ sync is turned off !
    sent from my Nexus 7 using tapatalk pro..
    schox likes this.
    01-04-2014 05:57 PM
  19. schox's Avatar
    ART didn't make any difference.
    I downgraded Instagram to the latest version in 4.x using this file.
    http://www.devfiles.co/download/Gql9...gram_4.2.6.apk
    Seems to work nicely - but of course no 5.x features...
    01-05-2014 06:44 AM
  20. tiltshiftfocus's Avatar
    Seems like no one realised that latest Instagram is using 100% (25% if quad-core) CPU be it foreground or background..
    01-09-2014 06:37 AM
  21. sandiegan79's Avatar
    having this same issue. Instagram fix your crap.
    02-05-2014 04:27 PM
  22. SaeedAwadX's Avatar
    This monitor screen is an app or built-in with your device?
    - - - Updated - - -
    02-07-2014 01:29 AM
  23. UJ95x's Avatar
    - - - Updated - - -
    I want to say it's GSam battery monitor, but I'm not 100% sure. It's definitely not a built in stat monitor though
    02-07-2014 01:49 AM
  24. umzy's Avatar
    This is happening for me also, and its soo annoying!! Need to find a solution quick! My phone heats up like crazy and battery just drains super fast. I run a couple IG accounts that I need to use!!
    08-10-2014 09:17 AM
  25. Frazzel 001's Avatar
    Happens to my Sony Xperia z1 and Samsung 8.4 s tablet... Wish they would fix this bug
    08-11-2014 03:00 AM
26 12
  1. Needed quickly plz : Android 4.3 XXUBMJ1 for note 3 N900
    By Osama Mohammed in forum Samsung Galaxy Note 3
    Last Post: 12-24-2013, 04:09 PM
  2. Nexus 7 (2012) Android 4.4 to 4.4.2
    By axdavies in forum Google Nexus 7 Tablet (2012)
    Last Post: 12-23-2013, 11:15 AM
  3. Bought Tablet - It arrived with ZERO Charge/Battery Life
    By Boomax24 in forum General News & Discussion
    Last Post: 12-22-2013, 08:32 PM
  4. Battery drain *screenshot*
    By luke318is in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 12-22-2013, 07:56 PM
  5. process android.process.media: frequentlyerror message
    By Chartres in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 12-22-2013, 01:50 PM
