Results 1 to 3 of 3
    Default Nexus 5 stuck in fastboot mode thing
    When I try to start the device normally it gets stuck on the loading screen with the animation.
    I go into that bootloader mode and try to restore it to wipe/restore it to factory settings but I get this:
    I must have f**cked something up when trying to root the phone...no idea what I've done and I have no idea why wiping the data isn't working.
    Any suggestions?
  2. #2
    Default Re: Nexus 5 stuck in fastboot mode thing
    Could be the flash memory of the phone fail, or you just need to format the cache partition:
    fastboot erase cache
    then format it to make it usable: fastboot format cache
    If that don't work, try to manually erase all the partitions and reflash factory image. Use this guide, follow step 5 to erase the partitions, but use this driver and Nexus 5 image instead of the ones for the Nexus 4:
    [GUIDE] Nexus 4 - Factory Image Restore
  3. #3
    yes you are right
  1. Nexus 5 launcher for moto g (apk)
    By MrFluffbear in forum Moto G
    Last Post: 01-31-2014, 10:07 PM
  2. Stuck on boot loop
    By DEano Cobb in forum Verizon HTC One
    Last Post: 01-05-2014, 08:11 AM
  3. Nexus 10 for 185 bucks
    By Macklesdaddy in forum Google Nexus 10 Tablet
    Last Post: 01-02-2014, 01:06 PM
  4. Replies: 0
    Last Post: 12-29-2013, 12:10 PM
  5. pics are not saved in my sdcard?
    By Carlos Alejos in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 12-29-2013, 11:24 AM
B
