1. Ray999's Avatar
    Hi there,
    I've done numerous searches online to try and find something that is close. I've found a few articles that are closely related, but not quite the same. Hoping to reach out to the community to see if anyone else is experiencing what I am encountering...
    Firstly I am running KitKat 4.4.2 on a Nexus 5 (non-rooted).
    Now, when it comes to the official Android Facebook application I've been using it on my Nexus 5 and my previous Galaxy S2. I use to always try and remember to place it in the background to minimise battery drain (I know this isn't perfect, but it did make a difference battery wise, because if I leave it in the foreground, the battery would drain).
    Recently I've been running a number of tests and I have identified whenever I receive a Facebook notification, battery drain dramatically increases (e.g. over 10% in an hour with no use (sitting idle (black screen) and locked). If I don't get Facebook notifications, then the battery life is solid and last for ages.
    So I tried:
    Disabling all Facebook notifications. I've then tested a number of times... I get a friend to send me a Facebook private message (they then SMS me to let me know when they send the Facebook message). My phone does NOT generate a Facebook notification message, BUT I notice the dramatic battery drain kicks in as described above (phone gets very warm as well) when they send the Facebook notification.
    * I then tried ending the Facebook task. This does nothing. The dramatic battery drain pattern continues.
    * If I turn the phone on and off, it stops the battery drain.
    * I've tried uninstalling and reinstalling Facebook. No difference, problem still occurs.
    * I'm using the latest Facebook application as at 30/01/14.
    I know the advice is to uninstall Facebook, but I'm just trying to see if anyone else gets this problem? I know I could also install Greenify, but I don't want to root my phone (yet) (and the non-rooted feature is something you need to remember to do - knowing me I will forget to force stop)).
    There was something similar on Facebook Messenger (which I don't have installed) (I just found a battery-draining bug in the Facebook Messenger standalone app, and have no idea how to report it to anybody at Facebook who can fix it. : Android)
    Any thoughts?
    Ray.
    01-29-2014 08:43 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! That is odd. Have you tried changing Facebook's refresh interval to Never? You can easily do a manual refresh by swiping down.
    01-29-2014 09:20 PM
  3. Ray999's Avatar
    Hi B Diddy,
    Yes. I can confirm I have refresh internals set to never for Facebook - so in summary the Facebook application settings are: Facebook chat (off), Refresh Interval (never), Messenger Location Services (off), Sync Photos (off), Auto-Play Videos (off). And as mentioned, Notifications (off).
    Now I did some more tests. After receiving a Facebook notification, I noticed the battery drain occurring. I decided to then run Greenify (non-rooted) and force-stop Facebook. This surprisingly did not stop the battery drain.
    Utterly weird.
    Ray.
    01-30-2014 12:56 AM
  1. Return button takes me to the beginning of facebook page
    By jawadnawaz in forum Android Apps
    Last Post: 12-16-2014, 04:18 PM
  2. Replies: 2
    Last Post: 03-26-2014, 06:56 PM
  3. Replies: 10
    Last Post: 02-10-2014, 12:53 PM
  4. Replies: 7
    Last Post: 01-30-2014, 07:07 PM
  5. Battery Problem
    By DaviPeixoto in forum Moto X (2013)
    Last Post: 01-29-2014, 04:54 PM
