Results 1 to 3 of 3
    Default Nexus 7 Falcon widget problem
    I'm having a small issue with the falcon widget.
    Im running 4.4.2 and I downloaded the Google now launcher
    ( so then I'm able to swipe left for Google now )
    When I'm using the Google now launcher the falcon widget is no where to be found. The app is in the app drawer but I can't activate the widget from there .
    When I run the stock launcher the widget is their under the widget section.
    Anyone have a solution? as I prefer using the Google Now launcher.
    Thank you in advance !
  2. #2
    Awesome Joe's Avatar
    Posts
    Global Posts
    7 Global Posts
    Default Re: Nexus 7 Falcon widget problem
    Press and hold on an empty space in GNL. Once the three options appear, tap "widgets". From there, find the Falcon widget, tap and hold it, and drag it to where you want it to be. That should do it.
    Sent from my iPod touch
  3. #3
    Posts
    Global Posts
    7 Global Posts
    It should look like this:
    Sent from my SAMSUNG-SGH-I727 using Tapatalk
  1. Nexus 4 multiple problems can't get it to work
    By Z3GMob in forum General Help and How To
    Last Post: 03-04-2014, 02:00 AM
  2. Photo viewing on Nexus 10
    By garryg in forum Google Nexus 10 Tablet
    Last Post: 03-03-2014, 02:06 AM
  3. Android TF701F problem with keyboard dock
    By Richard Dallaire in forum ASUS Transformer Pad TF701
    Last Post: 03-02-2014, 10:01 AM
  4. i9506 process system isn't responding problem
    By psa47 in forum General Help and How To
    Last Post: 03-01-2014, 10:19 AM
  5. A quick question about the Nexus 7 2013
    By Sassi666 in forum Google Nexus 7 Tablet (2013)
    Last Post: 03-01-2014, 08:20 AM
