1. Erwin Rooij's Avatar
    Dear users,
    Since few weeks my battery life get drained by my screen. My screen brightness is on his lowest and still draining like 20-30% battery life each hour. Sometimes my screen even drain in stand-by mode... Every other draining apps/things are off. Like sync mail and more are all off.. So its really a problem with the screen... How could I fix this?
    And then we have random reboots... My nexus 4 just reboot without any reason. Sometimes its reboot in stand-by mode and sometimes when I use my phone. But both without any reason to reboot... Someone know a fix?
    03-11-2014 04:41 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Try wiping the system cache partition, which can sometimes fix issues like this. You won't lose any personal data. Reset: Google Nexus 4 | T-Mobile Support
    03-11-2014 12:25 PM
  3. zorak950's Avatar
    The screen shouldn't consume power when it's off, but when it's on it will be the biggest battery drain by far. 20% per hour even on low brightness is well within what I'd expect, especially since the N4 has never been revered for its battery life.
    03-11-2014 03:03 PM
  4. Erwin Rooij's Avatar
    Hi,
    I did a factory reset. Random rebooting is solved now, but my screen still drains 20-30% each hour form my battery.. Do you know how to fix it?
    03-17-2014 06:26 AM
  5. Erwin Rooij's Avatar
    Zorak950
    Normaly my screen only takes lik 5-10% max in 2-3 days.. But since few weeks ago everything changed.. And battery life form nexus 4 was good for me 2-3 days is engough
    03-17-2014 06:27 AM
  1. Answering Incoming Call by Tapping on the Accept Button Screen
    By Ilti Cela in forum Android 4.4 KitKat
    Last Post: 11-09-2015, 07:59 AM
  2. Nexus 7 Battery Charger is both slow and sometimes drains battery WHILE shut off
    By Lolorz Dollorz in forum Google Nexus 7 Tablet (2012)
    Last Post: 03-11-2014, 11:30 AM
