1. jonnymayne1's Avatar
    Afternoon everyone,
    very new to the site and hopefully I've placed this where it needs to be.
    I have a Vodafone issued Galaxy S4 running with no root on 4.2 android. As the 4.4 update was recently released yesterday I go to check the OTA and its still showing only 4.3 is there, however Kies is stating 4.4 is ok and ready to go.
    I start the download and it runs till 69% download, jumps to 100% and the S4's screen changes to one that has the Android green bot and the message 'downloading .. Please dont turn off ". There is also a small block of text in the top left with ODIN written and a series of white text that resembles DOS on a PC.
    This stays like this for a long time and does nothing more, and from what I've read online it states that it could be bricked. However when unplugged and restarted the phone reboots and comes back to normal. I don't know why this is happening and I'm unable to find anything to help, hence the post.
    Any help would be great, and thanks in advance.
    Jonny
    03-13-2014 07:49 AM
  2. electronicwiz1's Avatar
    I think you have to get 4.3 first before it can even find 4.4
    Sent from my Nexus 5 using Tapatalk
    03-13-2014 09:03 AM
  3. jonnymayne1's Avatar
    I did not do the inital 4.3 update due to issues the S4 experienced with slow run times on the os and apps.
    But I would have thought with Kies allowing the update to go straight from 4.2 -> 4.4 it would be ok. Would you suggest that Igo 4.2 -> 4.3 -> 4.4?
    03-13-2014 09:29 AM
  4. electronicwiz1's Avatar
    Well you should. If 4.3 has problems, you won't have them for long when you get 4.4 after that.
    03-13-2014 09:36 AM
  5. jonnymayne1's Avatar
    I'll give that a shot an hopefully it will work.
    Thanks
    03-13-2014 10:14 AM
  1. MMS problems over Wi-Fi
    By TheMatrix31 in forum Sprint HTC One
    Last Post: 03-17-2014, 05:24 PM
  2. How do I separate Galaxy S4 alerts?
    By shtarker in forum Samsung Galaxy S4
    Last Post: 03-17-2014, 01:32 PM
  3. What S5 features will come to the S4?
    By rockitdog23 in forum Samsung Galaxy S4
    Last Post: 03-13-2014, 11:25 AM
  4. Problems in my Samsung Galaxy S4's Smart Screen Feature
    By Alextodd1 in forum Samsung Galaxy S4 Active
    Last Post: 03-13-2014, 07:35 AM
  5. How to set 'read out' incoming messages by default in S4?
    By Sammy3007 in forum Samsung Galaxy S4
    Last Post: 03-13-2014, 04:10 AM
