Results 1 to 8 of 8
    Default Galaxy S4 says it's charging but it's NOT! Please Help!
    My Samsung Galaxy S4 will NOT charge all of a sudden. This started yesterday. It gave me an error message saying that creating a customized of could be harmful and to press the volume down key to stop it before it starts. I pressed the down key to stop it. My phone was going dead. So after connecting it to its charger and rebooting the phone; it would chim]e and say that it is charging but it WILL NOT CHARGE! Arrhhhh!
    I have reset the s4 back to factory settings, I have tried x 3 other chargers that work fine with my wife's S4. I have also taken the battery and putnitnin my wifes s4 and the battery charges completely fine. PLEASE HELP!
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    17,646 Global Posts
    ROM
    Liquidsmooth ROM
    Default Re: Galaxy S4 says it's charging but it's NOT! Please Help!
    Welcome to the forums.
    The screen you got into sounds like Download mode, and should not have any effect on the charging port. You have eliminated the cable as it works in other phones, and the battery. I am inclined to think it is the port on the phone. One of the pins could be damaged.
    Phone Timeline
    'If we could change ourselves, the tendencies in the world would also change.' - Mahatma Gandhi
    Community Guidelines and also here
    That's what I was initially thinking as well but the whole error message just threw me off because the phone is only a few months old....
    I was just wonder I no if it could be some type of system bug or setting.
    Thanks!
  4. #4
    Posts
    Global Posts
    17,646 Global Posts
    ROM
    Liquidsmooth ROM
    Quote Originally Posted by cberry30 View Post
    Thanks!
    Possibly, but I doubt it...
    From a Liquid Nexus 5
    Phone Timeline
    Also. Did I mention that it says it's charging but the battery just won't hold a charge and continues to die out!?
    But even putting a n other battery in doesn't help or switching chargers.
  6. #6
    srkmagnus's Avatar
    Posts
    Global Posts
    7,434 Global Posts
    ROM
    Stock 4.4 (KitKat)
    Did you install a new battery replacement or used? Try a new battery and see if that helps.
  7. #7
    same issue here it shows charging but it wont. started yesterday. I turned off the phone and charged it did work but today its not even charging that way. tried charging through laptop and PC both still no result. Its rather draining. how can the charging port be damaged when I didnt even drop my phone or anything. I use it very delicately. please help!
  8. #8
    Hi, Same thing happend with my phone, Did you get resolution i.e. your phone issue solved?
  1. Spotify/GooglePlay songs do not play, sometimes...
    By JoshKt in forum Google Nexus 5
    Last Post: 03-29-2014, 06:38 AM
  2. battery life. was great, now not so much
    By 4m0wagen in forum Samsung Galaxy Note 3
    Last Post: 03-28-2014, 01:10 AM
  3. Phone says I have a text message but I don't.
    By PittsburghJake in forum Android 4.4 KitKat
    Last Post: 03-28-2014, 01:05 AM
  4. Htc M8 or Galaxy s5
    By Jake_15 in forum General News & Discussion
    Last Post: 03-27-2014, 01:45 PM
  5. Help about Tablet doesn't work in 3G
    By umby75fg in forum Samsung Galaxy Tab
    Last Post: 03-27-2014, 08:44 AM
