1. cberry30's Avatar
    My Samsung Galaxy S4 will NOT charge all of a sudden. This started yesterday. It gave me an error message saying that creating a customized of could be harmful and to press the volume down key to stop it before it starts. I pressed the down key to stop it. My phone was going dead. So after connecting it to its charger and rebooting the phone; it would chim]e and say that it is charging but it WILL NOT CHARGE! Arrhhhh!
    I have reset the s4 back to factory settings, I have tried x 3 other chargers that work fine with my wife's S4. I have also taken the battery and putnitnin my wifes s4 and the battery charges completely fine. PLEASE HELP!
    03-27-2014 09:36 AM
  2. Golfdriver97's Avatar
    Welcome to the forums.
    The screen you got into sounds like Download mode, and should not have any effect on the charging port. You have eliminated the cable as it works in other phones, and the battery. I am inclined to think it is the port on the phone. One of the pins could be damaged.
    03-27-2014 09:46 AM
  3. cberry30's Avatar
    That's what I was initially thinking as well but the whole error message just threw me off because the phone is only a few months old....
    I was just wonder I no if it could be some type of system bug or setting.
    Thanks!
    03-27-2014 11:57 AM
  4. Golfdriver97's Avatar
    Thanks!
    Possibly, but I doubt it...
    From a Liquid Nexus 5
    03-27-2014 01:37 PM
  5. cberry30's Avatar
    Also. Did I mention that it says it's charging but the battery just won't hold a charge and continues to die out!?
    But even putting a n other battery in doesn't help or switching chargers.
    03-28-2014 11:22 AM
  6. srkmagnus's Avatar
    Did you install a new battery replacement or used? Try a new battery and see if that helps.
    03-28-2014 06:11 PM
  7. Usman Tariq's Avatar
    same issue here it shows charging but it wont. started yesterday. I turned off the phone and charged it did work but today its not even charging that way. tried charging through laptop and PC both still no result. Its rather draining. how can the charging port be damaged when I didnt even drop my phone or anything. I use it very delicately. please help!
    04-11-2014 07:12 AM
  8. Vaibhav Kumar's Avatar
    Hi, Same thing happend with my phone, Did you get resolution i.e. your phone issue solved?
    06-30-2014 06:57 PM
  9. Carrie Piercy's Avatar
    We just started having the same problem with my daughter's phone. I suspect that it is a damaged pin. If it is, is this where we can take the battery out, and then take a toothpick and run it across the inside of the charging port? Or do you think the port has to be replaced? There are no android repair shops in our local town and I'd rather try to fix this myself if possible. Thanks for any help.
    03-19-2015 08:43 AM
  10. Autumn Northrup's Avatar
    I had same problem with my tablet it wouldn't charge but the battery said it was and it never dropped a percent I got fed up because I wanted to play so I restarted my tablet and it said battery was at 100 percent but before it was at 55 I don't know what happened I recommend yall restart it too
    05-30-2015 11:22 PM
  1. Spotify/GooglePlay songs do not play, sometimes...
    By JoshKt in forum Google Nexus 5
    Last Post: 03-29-2014, 06:38 AM
  2. battery life. was great, now not so much
    By 4m0wagen in forum Samsung Galaxy Note 3
    Last Post: 03-28-2014, 01:10 AM
  3. Phone says I have a text message but I don't.
    By PittsburghJake in forum Android 4.4 KitKat
    Last Post: 03-28-2014, 01:05 AM
  4. Htc M8 or Galaxy s5
    By Jake_15 in forum General News & Discussion
    Last Post: 03-27-2014, 01:45 PM
  5. Help about Tablet doesn't work in 3G
    By umby75fg in forum Samsung Galaxy Tab
    Last Post: 03-27-2014, 08:44 AM
