1. Janardhan Yaduvanshi's Avatar
    my nexus 7 isn't responding to auto rotation after update of kitkat 4.4.2....could anyone give solution for it?
    04-05-2014 10:29 AM
  2. neonworm's Avatar
    Have you tried a reboot?
    04-07-2014 01:34 PM
  3. Zak Nordon's Avatar
    I did a full factory reset on mine, and ur worked... For less than 24 hours. Sometimes sitting it down with auto rotate locked, rebooting, and unlocking it works, but either way they have to fix this, or my Nexus 7 is going out the window of a moving vehicle
    06-29-2014 11:21 PM
  4. zorak950's Avatar
    This probably isn't it, but it's worth checking if auto rotate is turned on in the device settings. Look under Accessibility.
    CompuDino likes this.
    06-30-2014 12:51 AM
  5. Johnny Long's Avatar
    My N 7 screen rotation stopped working with the recent (late June 2014) Android 4.4.4 update. Tried multiple reboots to no avail.
    Under SETTINGS, ACCESSIBILITY, the "auto rotate" option WAS already checked, but un-checking then RE-checking the box solved the problem. Voila'... now auto rotates!
    Hope this works for y'all too.
    Johnny
    07-09-2014 07:59 AM
  6. dogfac123's Avatar
    Reboot works temporarily, not a permanent solution for me.. I have to constantly reboot..
    07-17-2014 02:45 PM
  7. David Price8's Avatar
    10-15-2014 06:03 AM
  8. David Price8's Avatar
    Found solution!!!!!!!!!!!!!! You have to clear the cache of the nexus 7. Do a search for "reboot" and on android forums you'll see a step by step guide.I.e power on and when logo appears hold down volume button together until reboot screen appears. It's with screen grabs so easy to follow. Enjoy.
    Stef R and DancesWithBikers like this.
    10-15-2014 06:15 AM
  9. Stef R's Avatar
    It's very frustrating. The only way I can SOMETIMES get auto-rotate to work, is to completely turn off my tablet and then turn it back on again. But lately that doesn't even work. I've only had the tablet a few months, so this really should not be happening.
    10-21-2014 12:11 PM
  10. Stef R's Avatar
    tried it. didn't work for me :o(
    10-21-2014 12:16 PM
  11. CompuDino's Avatar
    BIG THANKS zorak950. I don't mess with Settings enough to even find where the auto-rotate switch was. I now have my rotate back working.
    My auto-rotate just stopped working and got stuck in landscape mode. Thanks to this thread, I (finally) found where the auto-rotate setting was. When I looked at the setting, it was checked to auto-rotate so I unchecked it, then re-checked it and happily that was all I needed to do.
    11-08-2014 12:58 PM
  12. Cares's Avatar
    Assuming you do not have the rotation lock setting enabled I think I have a solution for you.
    I had this same issue and I literally tried for 3 months trying to fix it. I finally found some obscure website with a fix. It involved opening up your tablet and basically "securing" one of the cables. After I did that I have not had a rotation problem anymore.
    미운오리
    11-12-2014 03:33 PM
  13. DancesWithBikers's Avatar
    My 2013 Nexus 7 quit rotating a week or two after updating to Lollipop. It's the first time I've had any trouble with it. Clearing the cache fixed it. Thanks for the tip!
    11-24-2014 01:01 PM
  1. Samsung s4 i9505 music player problem
    By Emil Kolar in forum Samsung Galaxy S4
    Last Post: 08-14-2014, 02:53 AM
  2. Problem During Flash Now Can't Open My Tablet
    By ofcourse in forum General Help and How To
    Last Post: 04-06-2014, 09:48 AM
  3. Problem with contacts
    By janpietjoris in forum Google Nexus 5
    Last Post: 04-05-2014, 12:24 PM
  4. Huawei valiant auto update issue
    By dubyahh in forum Huawei
    Last Post: 04-05-2014, 08:59 AM
  5. Nexus 7: Recommend a current, not-to-big external battery pack...!
    By sampoodle in forum Google Nexus 7 Tablet (2012)
    Last Post: 04-05-2014, 08:50 AM
