1. Susanna Su's Avatar
    Ever since i upgraded to 4.4.2 today my wifi wont turn on? (HTC desire 601) does anyone have a solution to this?
    Attached Thumbnails help? Wifi won't connect after upgrade 4.4.2(HTC Desire 601)-screenshot_2014-04-06-20-55-47-1-.png
    04-06-2014 08:00 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! You might have to try doing a full factory data reset. Make sure you backup or sync your data before doing so.
    04-06-2014 10:24 PM
  3. novice4T's Avatar
    hi I have the same issue with my desire 601, but now I fixed the problem, try this and hope it works as it has done for me.
    switch off your phone take off back cover, and take out sd card, switch phone on your wifi should be back as it was before, now put back your sd card. hope it helps
    04-18-2014 06:41 PM
  4. Frank Bevers's Avatar
    It is an intermittent thing; I also upgraded my Desire to KitKat. WIFI sometimes just can't be enabled. Rebooting is your only option. All used to work perfect until the KitKat upgrade :-(
    05-02-2014 07:21 AM
  5. chrismike's Avatar
    WiFi not also working on ma HTC one vx. am using the stock rom upgraded rom
    05-02-2014 03:37 PM
  6. xhugorichardx's Avatar
    THANKS SO MUCH, taking my SD work perfectly.
    It is so sad that the update was worst of worst updates.
    Hugo
    05-09-2014 02:27 PM
  7. DuneMessiah's Avatar
    Hi, having same issue. When I remove the SD card, wifi will turn on and connect. As soon as I put my SD card back in, same, wifi says turning on, but will not turn on.
    06-23-2014 12:51 PM
  8. Rajat Srivastav's Avatar
    i have got the same issue few days back ......Do not worry
    just power off the phone and then remove the battery and again insert it after 30 to 40 sec .......when ur phone will on wifi will be totaly fixed......i know its not any technical trick but it will work ...the reason behind it is that after phone update (kk) software cache memory is disturbed and by doing this the phone will cycle its software to normal ......
    07-01-2014 03:13 PM
  9. HOS79's Avatar
    Hello, I had the same problem with 4.4.1
    I turn my phone off, I put out my card and turn it on and it worked.
    THANK YOU!
    09-28-2015 11:41 AM
  10. Fulani Filot's Avatar
    W W...what a strange solution, but heck, since it worked for you, it should for others (these weird machines).
    Sent from my Samsung GT-I8262 using Tapatalk.
    09-29-2015 03:59 AM
  11. Fulani Filot's Avatar
    THANK YOU!
    Do you know if this or what else can help with camera failing to launch on 4.4.2
    Thanks.
    09-29-2015 04:01 AM
  12. Jennmar's Avatar
    This worked !! Thank you !!! My HTC desire 610 wasn't able to turn on WiFi as buttons were greyed out. I did this and hey presto ...sorted !!! You are clever !!
    09-13-2016 05:18 PM
  1. Replies: 3
    Last Post: 01-22-2015, 12:44 PM
  2. Unroot HTC One X that is on Consumer Cellular
    By durango992007 in forum HTC One X Rooting, ROMs, & Hacks
    Last Post: 04-11-2014, 06:46 PM
  3. Gear 2 Neo and S4 pairing.Help please
    By Razor664 in forum Samsung Galaxy S4
    Last Post: 04-10-2014, 09:16 AM
  4. files for htc one
    By nierrizk in forum HTC One M7
    Last Post: 04-07-2014, 07:41 PM
  5. Anyone having issues moving from Wifi to 3G?
    By nightdesigns in forum HTC One M8
    Last Post: 04-06-2014, 06:27 PM
