Results 1 to 7 of 7
    Default Wifi Problem
    Hello,
    I've recently updated to android kitkat on my Samsung galaxy s4 SGH-I337M and suddenly my Wifi stopped switching on. I would like to know how to fix this or if I could downgrade the OS to 4.3 or 4.2.2
  2. #2
    Default Re: Wifi Problem
    I would suggest a Factory Reset and then update..don't install anything just test. If the Factory Reset brings you back to the latest image (theoretically it should) try to adjust the WiFi.
    Failing that, install AutoMateIt and make a rule 'when phone on turn WiFi on' and see if the WiFi is then accessible. This may be an annoying work around.
    I tried the Factory Reset 2 times and it doesn't work.
    I'll try installing the AutoMateit.
    How about downgrading? Is there a way?
    EDIT: Tried the app, it didn't work
  4. #4
    Quote Originally Posted by damian_1993 View Post
    Next best thing if this isn't under warranty- root the phone!
    How can I safely do that?
  6. #6
    I don't think you could safely root a phone, there are always risks. As for how, do some research as each device is different. Make sure you backup everything you need, and pay attention to phone model, software version etc. As you're probably aware there are a lot of risks associated with rooting and I cannot guarantee that this will even help.
    Have you tried researching this issue specifically for your phone type?
    HTC One M7
    damian_1993 likes this.
    Yes, I tried everything that doesn't include rooting or downgrading. None of the solution worked.
    Thanks anyway I'll try rooting it.
  1. [PROBLEM] Samsung Galaxy Note 10.1 not working if pressing power button
    By msstaki in forum Samsung Galaxy Note Rooting, ROMs, & Hacks
    Last Post: 04-03-2015, 01:35 AM
  2. USB Charger/Heating Problem
    By coldtone in forum Google Nexus 5
    Last Post: 06-10-2014, 09:37 AM
  3. Sprint Galaxy Note 3: notification problem
    By Losonoso in forum Sprint Samsung Galaxy Note 3
    Last Post: 05-29-2014, 08:53 PM
  4. App to Files on PC on Phone via 3G/WiFi?
    By androidforum in forum Samsung Galaxy S3
    Last Post: 05-19-2014, 11:09 AM
  5. Replies: 0
    Last Post: 05-18-2014, 11:54 AM
