Results 1 to 8 of 8
    Michael Nancarrow's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Secure Vault/Lock for Images
    There are a large mass of individuals screaming over Android 4.2.2 through to 4.4.2 in regards to Vaults etc. not working- take Audio Manager, Stock Vault and NQ Vault for example. I have looked, re-looked and then re-re-re-looked into the matter. Whilst I store a lot of personal documents on my phone it also doubles as my work phone. In saying this, I do want personal photos to be..uh, well personal. Rooting is not an option. I want to find an application that can run Android 4.4.2 and have the capability to 'secure' my files- if not documents that's easily enough done, but photos of the least.
    Has anyone found an app that still has the capability to perform the above mentioned?
  2. #2
    xperia2995's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Secure Vault/Lock for Images
    'File locker' still works. Very simple app.
    Only one problem though, it can lock files onli in internal memory.
    Thus if you want to lock SD card files,
    Move to phone mem
    Lock
    Move back to SD card
    Manually ofcourse, thank you kitkat !
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by xperia2995 View Post
    Move to phone mem
    Lock
    I have reviewed the 'reviews' and note that everyone is saying that File Locker does not work with the newest update (Android I gather).
  4. #4
    xperia2995's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Michael Nancarrow View Post
    Dude, I use it on 4.4.2
    It works if you follow the above steps.
    Whats the harm? Try it out. Just a few KB.
    Use some dummy pics before you use your originals.
    Anyway dont expect the old gallery locks to work with kitkat. They simply wont allow it unless its in phone memory
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    xperia, I am using File Locker and it does work- few hickups here and there with the unlock & view but yes, it works. I have only internal memory anyway, so I may try the other applicants also.
  6. #6
    John G5's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sorry to dig up a grave. This is the only relevant thread I could find.
    I designed a Vault for kitkat overcoming SD card restrictions.
    http://forums.androidcentral.com/dev...er-kitkat.html
  7. #7
    Yatezy's Avatar
    Posts
    Global Posts
    312 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Just for reference mainly but if you add the file .nomedia to the file you want private it won't show up in your gallery.
    Or, the method I use, change the file name of your private folder by putting a dot (.) in front of it. For instance the file Naked Pics becomes .Naked Pics.
  8. #8
    tbone2000's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yatezy, thanks for the recommendation and you are correct that if you put a "." in front of the file name then the files no longer show up in the Video App etc., however, the folder doesn't show up anymore in file apps either except on my PC. Is there an app I can use on the phone that will show the folder, and I presume the file names, that start with a "."?
  1. "Unsupported Media type" for mms using stock messaging app
    By JMSGNG in forum Samsung Galaxy S5
    Last Post: 09-29-2015, 09:56 PM
  2. Widgets? Notifications on locked screen
    By drew_sf in forum Android 4.4 KitKat
    Last Post: 06-05-2014, 03:15 PM
  3. Fastest launcher for phone?
    By metalupyourmax in forum General News & Discussion
    Last Post: 06-04-2014, 05:01 PM
  4. Samsung Galaxy s4 zoom AP settings for Straight talk data ATT
    By Christopher John1 in forum Samsung Galaxy S4 Zoom
    Last Post: 06-02-2014, 07:04 PM
