1. majdi suliman's Avatar
    Like seriously...........
    Ive seen people use the phone for the same time and same way and still have 45%...
    My phone is like 1 week old..
    Attached Thumbnails galaxy s4 battery-screenshot_2014-06-05-13-25-06.jpg   galaxy s4 battery-screenshot_2014-06-05-12-42-48.jpg
    06-05-2014 06:32 AM
  2. Nihal Rathod's Avatar
    Okay! Dude the problem is your apps. maybe you have some apps that consume more battery. All you need to do is just go to the settings _ battery and check out which app does consume more battery.. Do you use 3G network? It only works for 7 hours on normal use. For high use it may work less. If the problem doesn't get solved go to the shop and try replacing.
    Sent from my GT-I9192 using Tapatalk
    06-05-2014 06:46 AM
  3. majdi suliman's Avatar
    Nope, no such thing
    Need help asap.!
    06-05-2014 11:24 AM
  4. stockwiz's Avatar
    I disabled google plus and google search because they'd wake my phone up constantly despite disabling just about all sync and location items within them. Now I can leave the phone on standby 12 hours and come back with it at 96% instead of 65%. Don't need or want all that constant sync and location tracking stuff.
    I can manually check for whatever I need myself as needed, which saves the battery from constantly monitoring for 'stuff' .. I have voice commands, etc. all OFF for now until I figure out what doesn't needlessly suck resources.
    06-05-2014 08:44 PM
  5. majdi suliman's Avatar
    Still the same!
    06-06-2014 09:04 AM
  1. Samsung Galaxy S5 Freezing
    By Mrbukchoy in forum Samsung Galaxy S5
    Last Post: 06-05-2014, 08:46 AM
  2. battery usage on my s4..
    By majdi suliman in forum Samsung Galaxy S4
    Last Post: 06-05-2014, 08:37 AM
  3. s4 not working on 3 network
    By donna1230191 in forum Samsung Galaxy S4
    Last Post: 06-05-2014, 05:13 AM
  4. S4 Weather Widgets
    By Dejan Osterreicher in forum Android Apps
    Last Post: 06-05-2014, 03:24 AM
