@Golf and cappie.
The reason I said 2% an hour is not normal is because
1.I have tested the phone in airplane mode and still battery drains.
2.With the exact same phone and conditions(same position, freshly restarted), I have obtained only 0.1% decay per hour even without flight mode on another day.
Since the phone was sleeping, nothing must consume power ideally in airplane mode.
If the same phone behaves differently on two different days. I wouldnt say the decay is normal because it is capable of doing better.
@Alemuit.
If the tower communication was the power sucker, "Cell standby" would be way higher.
@Cappie
And yes my phone and everyones phone will die in 3hrs if we use wifi for the full time.If I play asphalt then it will go from 100to15 within an hour etc. (No one mentions that they use all that)
@Golf
The other guys graph. I dont know which of the two you meant.
Wifi is way above normal, thus his wifi was "turned on" despite him not using it.
And his google search app is clearly a culprit. I suspect he has google voice or locations enabled, thus it is contantly using the microphone or pingin location.
The second guy has bluetooth on. Haptic feedback is probably also enabled.
1. The battery will still drain in Airplane mode, just not as much.
2. There are always too many variables to consider when regarding conditions. Social media, emails, etc, if all are working properly, not getting stuck in a process (Facebook is nefarious for this). My current battery stats are 70% drain in nearly 12 hours (will provide a screenshot in a few minutes). A little low for me, but no big deal.
The phone will always drain when on. Period. The OS will account for the drain. That is why when a device is left alone, the Android OS accounts for the drain because that is the thing that is responsible for the drain.
The same phone behaving differently can be due to many things. Cell signal strength is a big factor, which brings your counterpoint to Almeuit; Cell standby doesn't really go up the charts unless the signal is not there for a large period of time.
The other guys graph I was referring to was the fact that in the graph chart, you can see that the time on battery was 6 hours and minutes with the 94% drain. That is not a good thing. Yes, his bluetooth was on, but how long was it on? I don't know. It could have been on for 5 minutes.
Google search is not the culprit as it only took about 7% of the total drain.
How do you know haptic feedback is on?
Currently for those who face massive drain.
1.Checking with a friend with same phone
2.If the phone was ever updated or came out of box with same OS version.
3.Did many another company phones have the problem.
4.Auto sync may be enabled, causing massive update downloads during wifi use (plus wifi signal or phone signal may be too weak)
5.Location services would have been enabled. It must be disabled.
6.Haptic feedback must be turned off.
7.Do not leave bluetooth, wifi, 3G data ON. Some people falsely believe that leaving it on has no effect unless you use it.
7.Google Play Services unwantedly opens upto 5 services. Force close them.
A solution to such a person.
Freshly restart the phone with 100% battery. Then begin force closing every single app.(except core) The important ones will auto restart.
If you have developer option enabled.
Check >display cpu usage.
Observe the recurring activities.
1. Checking a friend with the same phone: again, too many variables. Even on the same carrier, there are different quality radios in each cellphone, what does each person have connected to their phone, etc.
2. Irrelevant. I am on 4.4.3 right now on a custom ROM and I have no excessive drain what so ever. Out of the box I was on Sense 6 4.4.2.
3. Not sure what you are trying to get at here.
4. Auto sync for me and many people I know, hasn't affected battery life. Yes this
can account for it, but not the first thing I would look at.
5. My location services are set to battery saving. No ill effects here.
6. Yes, the vibration is a battery killer, but nothing to the scale of excessive.
7a. Yes those will contribute to more battery drain, but again, not to excessive.
7b. Force closing Google Play Services will last only as long as you don't open up Play. And even then Services will re open eventually. Force closing it continually can actually lead to battery drain as the OS will start the application back up.
