1. andyw80684's Avatar
    ON 4.4.2 note 3 w/ verizon
    I am only getting about 2 hours screen on time now. This is awful...if my phone sits idle for 2-3 hours it will be at 0% what can i do to fix this.
    have tried
    factory reset 3 times...nada
    battery calibration--drain till 0 then charge while off to 100%..nada
    any ideas guys?
    07-31-2014 07:53 AM
  2. VDub2174's Avatar
    When you go into the battery settings, what does it show as using most of your battery?
    07-31-2014 07:59 AM
  3. andyw80684's Avatar
    Android os
    Android system
    Always top 2..screen is 3rd which is to be expected
    07-31-2014 08:01 AM
  4. VDub2174's Avatar
    Hmmm......do you have a lot of apps syncing in the background?
    07-31-2014 08:06 AM
  5. andyw80684's Avatar
    No Gmail and google+ is all really
    07-31-2014 08:07 AM
  6. dpham00's Avatar
    Can you post gsam screen shots?
    Sent from my LG G Pad 8.3
    Golfdriver97 likes this.
    07-31-2014 08:12 AM
  7. andyw80684's Avatar
    yes I can I did a reset last nightso now I need to reinstall it how long should I let it run before I get a accurate post that I can put on here
    07-31-2014 08:14 AM
  8. Golfdriver97's Avatar
    Or even Android Screenshots?
    07-31-2014 08:15 AM
  9. Golfdriver97's Avatar
    Go about 60-70% usage.
    07-31-2014 08:16 AM
  10. andyw80684's Avatar
    okay I'm going to charge it up to a hundred and let it run down to 60% and then I'll post the screenshot thank you for the help
    07-31-2014 08:19 AM
  1. Google maps different on Galaxy 5 and Droid Maxx
    Last Post: 03-31-2015, 04:05 PM
  2. Samsung galaxy s4 using too much data
    By Xegano in forum Ask a Question
    Last Post: 08-04-2014, 07:18 AM
  3. my galaxy note 2 security
    Last Post: 07-31-2014, 01:06 PM
  4. verizon soft brick help
    Last Post: 07-31-2014, 07:48 AM
