BLU 5.0k phone won't detect computer and USB mass storage mode won't enable.
Hi all, I have a problem getting my phone to recognize that it's connected to a computer. It is a BLU 5.0k with android 4.4 and a menu is supposed to appear in the notification area when it is attached by USB to a computer, but it does not. I have already tried all the obvious fixes and determined it is a android software problem, It's not my computer, or the cable, or the port on my phone. It always charges fine, and if I play with the "USB debugging" setting, I can sometimes get the phone to connect, but then it doesn't work again if I unplug it and replug it.
A factory reset did not fix the problem. I also cleared the cache in the boot menu, and there is no new update for my phone. It has worked fine in the past without any drivers even after I rooted it, but now it doesn't even show up in device manager. My USB ports are all 2.0, and I've tried different data cables.
I really appreciate any help with this, I'm totally stumped.
