my phone battery is draining fast without use after i made a factory reset. and when i go to battery from settings to see what application is using the most of it i found that "Android System" is using more than 70% of it.
i tried to disable every thing running from wifi and gps but nothing.
i suspected that there is another third party app doing this so i did factory reset again and didn't even enter google account into the phone and still draining fast from android system.
I don't have sd card if anyone asked.
is there any solution for this?
even if i have to flash a custom rom to the phone?
