I have an LG Optimus Exceed 2 that up until a day ago worked fine.
I rebooted it and all heck let loose.
Booted fine, but WI-FI sits there trying to turn on and when I try to turn bluetooth on it tries, but never succeeds.
Also I had to reinstall a few apps and sometimes when accessing some settings the phone reboots, but gets stuck at the red verizon screen.
yesterday I rebooted to the menu and cleared cache then rebooted to safe mode and it did that ok.
At some point phone rebooted and all was well. I then rebooted this afternoon and have the same symptoms only none of my apps are affected.
Any idea what the problem is?
Also is it possible to flash a factory ROM without loosing any of my text messages and if not is there a way to export them?
EDIT:
Found out it doesn't get stuck at the red verizon screen. It continues on with the boot.
EDIT:
