Results 1 to 11 of 11
Like Tree3Likes
  • 1 Post By thatguy97
  • 3 Post By JRDroid
    Alexandre Amicone's Avatar
    Posts
    Global Posts
    12 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Anyone willing to help a noob flash Android L on my Nexus 5
    I have a Nexus 5, I have a windows computer, cable, and nexus 5, and I am looking to flash the recently released factory image. Any help would be great. Let me know if you want to do this via hangout or whatever. Thanks in advance
  2. #2
    draconianchaos's Avatar
    Posts
    Global Posts
    294 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Anyone willing to help a noob flash Android L on my Nexus 5
    It should be the same process as flashing any factory image. I'm hoping to dive into flashing l on one of my devices early next week. If you don't get the help you need before then I'd be happy to go through the process with you.
    Nexus 5 l image : http://developer.android.com/preview/setup-sdk.html#top
    AC's article on updating nexus devices : Updating your Nexus — Everything you need to know http://www.androidcentral.com/how-up...finitive-guide
  3. #3
    dnafog's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
  4. #4
    Posts
    Global Posts
    294 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    That is just a guide to enable art in 4.4 art was more of a placebo in KitKat...
  5. #5
    Brian Low's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    hope you aren't going to be using the nexus 5 as your daily driver with L preview. I wouldn't recommend it.
  6. #6
    thatguy97's Avatar
    Posts
    Global Posts
    773 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm using it as my daily tablet driver and all my app work even the infamous with updates MX player works Android L is REALLY good for apps that aren't optimized yet for the new design ya I put a third party keyboard on and there's no dismiss all notifications buts its solid
    trandz likes this.
  7. #7
    JRDroid's Avatar
    Posts
    Global Posts
    1,553 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Brian Low View Post
    It is daily drivable so long as you know what you're getting into. There aren't random reboots or crashes and the core apps all work. Some apps do not work entirely (or at all). Netflix crashes if you try to Chromecast for example. You can't install HBO Go because the no device with L is on their approved device list. Despite this, the phone remains entirely usable and stable. A lot of these issue will start to go away in the coming weeks as developers update their apps (as the whole point of the dev preview is that they can update their apps prior to the mass release). I wouldn't recommend it for everyone, but so long as you know ahead of time what to expect, it is perfectly stable.
    Mooem, MLdroidN4 and Aquila like this.
  8. #8
    Adiliyo's Avatar
    Posts
    Global Posts
    3,278 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    if reading the instructions that are written on the same page as the images is too complex for you, i would say that running prerelease software is not what you should be doing.
  9. #9
    Gary Holly's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I think you should take a look at skipsoft.com. great for dealing with flashing,unlocking and rooting.
    Most of the work is done for you,just follow the steps it outlines for you.
  10. #10
    TrinNY's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The guide on Redmond Pie is pretty good it's the one I used I hadn't flashed since I rooted my old Nook eons ago so I needed a refresher
  11. #11
    Brian Low's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by jdevenberg View Post
    I mean it's up to you if you want to or not. It's a developer preview for a reason, bugs are bound to be everywhere. There's a forum in the nexus 5 thread that have people messing around with L preview. It doesn't seem very good to me at the moment lol.
  1. Backup app running on, and backing up to a hard drive
    By Ted Kurkowski in forum Samsung Galaxy S5
    Last Post: 12-08-2016, 06:57 PM
  2. Replies: 1
    Last Post: 02-03-2015, 12:12 AM
  3. Replies: 1
    Last Post: 09-01-2014, 12:56 AM
  4. headphone jack on lg g2
    By harley1234 in forum Ask a Question
    Last Post: 06-26-2014, 04:25 PM
  5. Help! First time flashing firmware, didn't go so well!
    By kbreudi in forum Verizon Samsung Galaxy S4
    Last Post: 06-26-2014, 02:36 PM
