Results 1 to 6 of 6
    Gokul Raj1's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Battery life in l
    Hello,
    Anybody whos using L version in nexus 5 can tell me how is the battery life after upgrading to L? thanks in advance...
  2. Best Answer
    Really impressed so far. I disconnected from my charger around 11am and I just now got a notification telling me that I was at 15%. That was with WiFi, sync, and GPS on fully.
  3. #2
    BillLee3's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Battery life in l
    Quote Originally Posted by Gokul Raj1 View Post
    Hello,
    I'm was having issues with "Miscellaneous" taking up a very large %. In standby life seemed on same order as KitKat, but in using it life seemed quite short. Had to revert because tethering doesn't work and I use that all the time with my Nexus 7.
    Sent from my Nexus 7 using Tapatalk
  4. #3
    gregs1213's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    AOKP (M5) Franco (M4)
    I got excellent results using the battery saver mode.. I got 21 hours of use and 4.5 hours of on screen time with High Accuracy GPS on. I've never got close to that without it. I am good above average results without it.
  5. #4
    Gary Holly's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I get about 3.5 hours(High Accuracy GPS on, also bugged and wont shut off for me) a On screen time now vs 2.5 hours on 4.4.4 with some **** on.
    Now that being said, Android L is known to trip balls and battery can drain from various bugs with apps. but over all, things will be great when said issues are fixed.
  6. #5
    AustinIllini's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by BillLee3 View Post
    Seeing similar issues on the Nexus 5. Miscellaneous and the like taking up large percentages of usage.
  7. #6
    EnigmaticPsychotic's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
  1. smart text feature in Note3
    Last Post: 09-01-2014, 02:43 AM
  2. Battery Problem
    By willheryanto in forum Samsung Galaxy S3 I9300
    Last Post: 07-03-2014, 08:39 AM
  3. Does towelroot work in the android l decolper preview?
    By darth android in forum Android L Developer Preview
    Last Post: 07-01-2014, 10:17 AM
  4. plugged in sign when its not charged
    Last Post: 06-29-2014, 12:52 PM
  5. Can't get rid of suggested user id's floating above log-in
    By Tom Concolino in forum Samsung Galaxy Tab 3
    Last Post: 06-29-2014, 07:35 AM
