1. Asheshk's Avatar
    Can anyone tell please either I will sell my xperia z and buy moto x
    08-13-2014 06:12 AM
  2. STARGATE's Avatar
    According to many tech sites it will, depending on your model.
    Check Sony's site regularly for the best answer to your question.
    http://blogs.sonymobile.com/tag/xperia-smartphones/
    Sent From The 5th Galaxy Inside The Time Vortex.
    08-13-2014 06:56 AM
  3. Asheshk's Avatar
    Thanks dude.. Let me tell you my model is c6602
    08-14-2014 02:23 AM
  4. salmanahmad's Avatar
    Sony usually follows a 6 month schedule for flagship device releases, a Z3 is just around the corner.
    The Xperia Z isn't highly likely to get Android L but there are some decent chances that it will.
    But even if it doesn't get Android L, the Xperia Z is a very amazing device, even today.
    If I we're in your position, owning an Xperia Z and not getting Android L, I would root it and install Cyanogenmod.
    Best of luck and let's keep our fingers crossed.
    08-14-2014 05:39 PM
  1. Hello Android...
    By Stwutter in forum Introductions
    Last Post: 08-14-2014, 03:24 AM
  2. Replies: 1
    Last Post: 08-13-2014, 05:39 AM
  3. I will ask this again.....
    By RoswellWitness in forum Ask a Question
    Last Post: 08-13-2014, 03:15 AM
  4. PlayerPro Skin Android L
    By Karsakoff in forum Wallpapers, Ringtones, and Themes
    Last Post: 08-13-2014, 02:07 AM
