No LED flash on silent?
jaleelhamid
555
I just updated my Samsung s5 and with my phone on silent I noticed the LED doesn't flash with notifications? Any fixes? Its lollipop. 5.0
Is there a way to put the phone on 'silent' or 'None' as it's called in lollipop and still get make the LED flash when we get a notification?
It is on LL 5.0.2 but a quick Google suggests it may not be there on 5.0 but not totally sure on that.
I would suggest trying either Light Manager (my personal preference) or Light Flow where you can highly customise the LED notification settings.
I Downloaded light flow but on silent the LED lights don't work once I turn the sound on it works.
I'm running Lollipop 5.0.2 and I can see the pulse notification setting and although it's turned on, the light only blinks of the phone is on 'All' or 'Priority' mode and not when it's on 'None' mode... Running vanilla stock android with no Light manager apps...
kctraci1
