A
AC Question
Lollipop update causing battery drain
I have had a Galaxy Tab S 10.5 for about 8 months. Fabulous device. Auto update sis on by default. 5 or 6 days ago I was prompted to install Lollipop 5.0.2, an 185Mb download. I promptly did so.
Big mistake. I have 2 serious issues;
1. battery drain makes it almost unusable. I can literally watch the meter drop with just plain internet browsing. It will drain maybe 15% or more in an hour
2. I use Chrome as browser of choice. Now I get frequent "Aw Snap" freezes when I never had any before.
I am sure I am not the only one. Hopefully someone can suggest some fixes for this buggy O.S. If I could revert to KitKat without a factory reset I would, I dislike this so much.
All help gratefully accepted.
Thanks
John
Thanks
John
