Android OS battery drain after 5.1.1 update
Hello, I have a T-Mobile Samsung Galaxy s5 and its running Android 5.1.1. Ever since the update, I've noticed that Android OS has been using battery the most. Worst of all, if I leave the phone on sleep for a few hours, the battery starts to drain. I have sync turned off, Bluetooth off, WiFi off, I don't have apps that pull background data and I disabled all of the ones I don't use. The only apps I use throughout the day are textra (for texting), Flipboard, and I make a few calls. In the attached image, it shows the stay awake time for Android OS which is exactly the same amount of hours from which I didn't wake up the phone. Also a few nights ago, I went to bed with 63% battery and woke up with 49%. At the top of the battery usage chart was Android OS, followed by Android system, then screen. I never had this problem prior to 5.1.
Thanks in advance.
Thanks in advance.
