Hello!
I just updated to Android 6.0 Marshmallow yesterday, and now I'm wondering about missing and changed settings. Are these solvable issues or just something I have to try to live with now(reroll back to earlier version).
1. No additional info on lock screen.
On earlier version I could have Weather and Pedometer information on the lock screen, now they have disappeared and there is no longer a setting for them under the Lock Screen -settings.
2. Swipe to unlock
Anyway to disable this? Annoying and useless...
3. Edge screen always visible
I had this setup so that Edge screen was only visible in the home screen. Now I can't find this setting anymore either and thus it is visible everywhere. Issue or, anyway to do it as it was?
Cheers!
2. Swipe to unlock
Cheers!
