1st off verizon has pushed the Android 6 update to my phone. I refuse to update because I've heard of some major issues with 6. Also from what I understand, in the new update, the quick launch apps are removed and have been replaced with just a voice command launch. I don't want the voice command as I'm always in noisy environments and its much simpler to just swipe the app that I need. So, is there a way around that, or do they still give you an option to use the quick launch on the lock screen?*
Second, since I updated to lollipop a long while back, my sounds aren't as loud as pre lollipop.* Am I stuck with the lower sound level if I stay with lollipop?
Third, how do i give and remove ext sd card write permission? I know you're able to give after the install of a new app, when the new app first goes to write on it. I'm wanting to change after after the fact.
Thanks for your time and help, I greatly appreciate any help. JD
