I'm using DP3 on a Nexus 5X. I just realized that while the notification LED works for incoming SMS, it does not for a missed call or voicemail. I have it set to "Pulse Notification Light" but beyond that I see no other options that could disable it.
I could swear it worked in stock MM and maybe even the last time I switched from MM to N. If it makes a difference, this install was a clean fastboot flash with no app restore as opposed to an upgrade from MM via the beta program OTA. ??
Paul
Paul
