Is anyone else having the problem of Bluetooth disconnecting while on a call? I own two Plantronics Pro HD earpieces - both worked fine on MM - but on N DP 3 and 4, the earpieces will disconnect, and then reconnect 1-2 seconds later. However, after reconnecting to my N5X, they do not reconnect to the call I am on - I must manually toggle between speaker and earpiece a couple of times to get the earpiece connected back to the call.
I have reported this to Google - just wondering if anyone else is having this problem.
NEXUS 5X on AT&T on N DP4
