1. Vfrenchy French's Avatar
    Hi, do we're all aware of the android N Battery Drain issue, I've been experiencing this issue since updating over a month ago. I'm using the LG Stylo 2 LGLS775, which runs a 3000 miliamp battery, my battery life has decreased dramatically. I've included two screenshots below. I've made a complete phone reset before making this article and tried resting all app preferences before that, which i heard may help the issue. Someone please help out if possible, I'd really appreciate it. Thanks in advance.
    Attached Thumbnails Android N Battery Drain Need Help!-screenshot_2017-04-21-09-57-39.png   Android N Battery Drain Need Help!-screenshot_2017-04-21-09-57-44.png
    04-21-2017 09:05 AM
  2. Golfdriver97's Avatar
    Welcome to the forums. You could try a cache clear, although a reset should have taken care of that part. You can do that in Settings>Storage. Click on the cache section. Afterwards, try a reboot
    TGIS likes this.
    04-21-2017 10:15 AM
  3. Trigati's Avatar
    Wipe the cache partition too. You may need to Google the instructions for a LG phone. I don't know if it's the same as the Nexus/Pixel line or if they changed it as Samsung did
    04-21-2017 02:02 PM
  1. A very important step everyone needs to do, at least Verizon customers
    By trucksmoveamerica#AC in forum Samsung Galaxy S8 & S8+
    Last Post: Yesterday, 03:41 PM
  2. Replies: 1
    Last Post: 04-21-2017, 07:39 PM
  3. proces.com.android.systemui has stopped working. Please help
    Last Post: 04-21-2017, 07:34 PM
  4. Replies: 1
    Last Post: 04-21-2017, 10:47 AM
  5. android auto not working after last update?
    Last Post: 04-21-2017, 07:01 AM
