1. I_didnt_do_it's Avatar
    Hello, I was wondering if on my galaxy S6 Edge that just updated to nougat if if I could enable the system ui tuner, or does it have to be stock android to do that. I pull down the quick settings menu and long press the gear icon in the top right corner for 10 seconds, and releasing it just scrolls out of that menu bar. I'm thinking it's because of touch wiz, and not having stock android.
    05-11-2017 03:41 PM
  2. hallux's Avatar
    I'm not sure about "stock" being required, just need to find a manufacturer that doesn't mess with the OS too much
    05-11-2017 08:54 PM
  3. badcat's Avatar
    I don't have a Samsung Phone but have you disabled the animations via Developer Options? The animations need to be on at least the minimum setting (not off) for that to work. Been burned by that myself.
    Edit: I just tried it on my Samsung tablet and couldn't get it to work. Might be a Samsung thing.
    05-12-2017 05:35 AM
  4. Javier P's Avatar
    Yeah, it's a Samsung thing, they didn't enable the UI tuner in their devices.
    badcat likes this.
    05-12-2017 05:42 AM
  5. I_didnt_do_it's Avatar
    Well that bites. Kind of waters nougat down if you ask me. Disappointing g, but it is what it is.
    05-12-2017 10:56 AM
  6. kbz1960's Avatar
    I thought it was a double tap on the icon, or more?
    05-18-2017 09:25 AM
  7. hallux's Avatar
    Long-press on the gear at the top of the quick settings panel, unless you have a Samsung, then it won't work.
    05-18-2017 09:54 AM
  8. kbz1960's Avatar
    Yep, I did it awhile back. Forgot how it was done.
    05-18-2017 10:12 AM
  1. Replies: 3
    Last Post: 05-21-2017, 09:11 PM
  2. How to stop download of mail
    Last Post: 05-12-2017, 04:08 AM
  3. How do I add color back to my contact icons?
    Last Post: 05-11-2017, 04:21 PM
  4. No street names on google map; android tablet
    Last Post: 05-11-2017, 03:33 PM
  5. Where is the "back button" on samsung galaxy tab A?
    Last Post: 05-11-2017, 02:56 PM
