Results 1 to 5 of 5
- 04-29-2010, 10:50 AM
Thread Author #1
Weather Widget Help
Hey All,
So I put weather widget on my phone and it is cool..
However, I notice it does not update it's self to where I am located..
I remember when I installed it, it asked for my zip code, ok no problem there.
But I thought I remember it saying it would only use that if it could not determine where I am located.
Well, it does not update to the current city I am in? Does this not do that?
I can see the VZW Tower from where I am at..
Thanks. - 04-29-2010, 12:29 PM #2
Which widget are you referring to?
I don't think beautiful Widgets updates automatically. You have to refresh the widget manually. - 04-29-2010, 12:33 PM #3
Tap on the weather icon, it will open up a new screen. Hit menu and check your settings. How often have you set it to update?
If you have it set at 2 hours it will update every 2 hours. - 04-29-2010, 12:50 PM #4
I quit useing the stock weather widget, it never real time updated like i wanted it to. i use weather bug elite, it does follow me on the map as well as update automatically as i pass each tower...very good app, worth the money, it also gives bad weather alerts and amber alerts as well, plus the live radar is excellent.
- 04-29-2010, 01:18 PM
Thread Author #5
Reply
