Results 1 to 5 of 5
    Default Go sms pro help
    I have two questions about Go sms pro.
    How can I get it to vibrate like the stock sms app? I've went through the settings, and can barely feel any of them in my pocket.
    And how can I get it to use the contacts are in my phone, not from my sim card?
    Thanks.
  2. #2
    Default Re: Go sms pro help
    The only option is to set the vibrate pattern to normal, long, multiple short, multiple long, and custom.
    This is located in the notifications menu.
    Hope this helps.
    Quote Originally Posted by goceltics34 View Post
    Hope this helps.
    Ya I know that, and none those are as good as the stock sms vibrate...
  4. #4
    The Custom option allows you to edit it to vibrate how ever you want, so you could set it to the default sms vibrate if you wanted to.
    You have to enter numbers and the numbers are in Millis
    the first number is when it starts vibrating usually 0
    Then its MillsON MillisOff or the amount of time it vibrates and the amount of time until it vibrates again.
    You can mess with it all you want and create cool vibration patterns.
    Myself I like the default pattern like it seems you do, I have mine set to
    0,200,300,200 and it is very close to the default vibrate pattern
    hope this helps.
    RH
  5. #5
    Default
    ⓗⓞⓦ ⓣⓤⓡⓝ ⓞⓕⓕ ⓝⓘⓖⓗⓣ ⓜⓞⓓⓔ ⓗⓔⓛⓟ please
B
