Results 1 to 3 of 3
    crisg723's Avatar
    Posts
    Global Posts
    98 Global Posts
    Default OfficeSuite Pro vs Quickoffice Pro
    Just wanted some feedback from the community as to which one of these applications most people prefer. Reading the descriptions of both it is hard to tell which one is more feature rich.
    Sent from my MB860 using Tapatalk
  2. #2
    Default Re: OfficeSuite Pro vs Quickoffice Pro
    I have used these two plus Docs2Go. I use it primarily for a spreadsheet that I need everywhere I go. It's on GoogleDocs. Docs2Go does great with it but QuickOffice makes it look a little better and IMO has a better search function within the sheet.
    So for the one thing I use it for, QuickOffice is better to me. YMMV
    How amazing is it that Amazon puts these apps out to us for free? Keeps me a loyal Amazon customer. So it's working, I suppose. Thanks!
    Possum Pete
    I'm Not Dead!
    Galaxy Note 2
  3. #3
    Xopher's Avatar
    Posts
    Global Posts
    4,722 Global Posts
    ROM
    All Stock
    Default
    I've used all three as well. One thing I found was if I edit files in QuickOffice or OfficeSuite, they will no longer open in DocsToGo. Plus, DocsToGo won't let you change input method. I often change keyboards depending on what I'm typing and which part of the app I'm using (spreadsheet vs document). That made DocsToGo cumbersome.
    The issues I had with QuickOffice were with formatting. An office doc had the last paragraph with no new paragraph market (pressing the enter button to go to the next paragraph). QuickOffice didn't show the entire paragraph. I opened the file in OfficeSuite, pressed enter and saved, then it looked fine in QuickOffice. The next paragraph didn't keep any of the previous formatting, though.
    OfficeSuite has become my favorite right now. Formatting does what I expect, and it works pretty good. I would say they all have their own quirks. It's more about finding which one works best for you.
    RuneCryption - Unique memory puzzle game for Android. ( Google Play - Amazon Appstore )
B
